Hey guys, couldn't find anything else really answering this question.
Just bought a front strut bar for my r33 skyline. I've heard a few things regarding the installation, and I have a few questions and concerns.
Firstly I was told to install, I should jack the car up and have the front in the air. My question for that is, if undo the bolts to hold the strut bar on, won't my suspension come out?
Secondly I was told the struts need to be sitting as close to 90 degrees as possible, how am I meant to even check or insure this? I would have thought having the car on the ground would have kept them closer to the right place?
Thirdly, some say it will and some say it won't affect my wheel alignment (mostly camber I presume). I really didn't want to fork out for another wheel alignment... But will do what must if it is required.
Advice, info, tips? Thanks.
https://www.sau.com.au/forums/topic/346654-front-strut-bar/
I can't see how the hell it would affect wheel alignment, I'd say that's a myth...
I'd recommend jacking the car up enough that the wheels are just touching the ground, but not putting any weight on the suspension - this way they don't fall out so to speak when you undo the nuts holding your struts in, but they're also not going to move about at all.
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5580500
Lol,
I'm pretty confident that all suspension bits should be tightened while the car is sitting on it's own weight. Nothing should be loaded except due to gravity, unless you want it to be.
You should not notice any changes in alignment.
And, if you do fit the brace when the car is sitting on the road, wheel alignment will not change.
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5580526
Yeah I think I'll do it with the car sitting flat on the ground, as if do it lifted it is more likely to create some degree of change, or possibly put un-necessary pressure?
At least this way I know it is set to how the car normally sits.
Next time I do get a balance and alignment done, I can ask them to check the settings of the strut bar and if necessary tighten it a bit when they have the car lifted, and then do all the alignment.
It would have only been the camber that changed.. But was told should lift the front to take any strain off the suspension for when doing the job. I'll give it a go when can once pick up the strut bar - hopefully this arvo.
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5580598
as eiji and nathan said, its ment to be done with the the car on the ground.
Just remove the strut nuts, adjust the bar till it just slips over the top and then do the nuts back up.
you wont need an alignment and you be suprised wiht the difference in the front (at least i was, but thats in a bendy 31)
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5580698
Pedders where I got my whiteline bar from still insist it won't work unless I lift the front properly. So that all the stress and pressures are off the body, and to attach it and tighten it up properly before lowering the car back to the ground...
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5580752
Lol @ Pedders!
Just undo the 4 nuts, stick strut bar on and do it up!
To be honest a strut bar does sweet fa on a skyline, you are better off with a caster rod brace imo.
Ive done track days both with an without the strut brace on the same suspension and didn't notice any difference.
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5580767
Strut bar - To preload or not to preload that is the questionSo. I had the oppertunity to drive my car without preloading and then preloading the strut bar. Story goes was trying to install my strut bar in my driveway with only basic hand tools and my cars own floor jack. jacked up one side and put my hand under the fender and slipped the bolts in and tightend them from the top. I can say after going for a test drive it made a real big difference.
After driving for awile i put the car on a lift today and then took off one end of the strut bar and it was dificult to pull off. Once off it wouldnt go back in easily being it was under tension while being installed. But not the kind you would want. I could actually turn one of the ends maybe 4 full turns. Reinserted it back and tightend the nuts up. Now the bar is under a slight tension. Put the car back down and went for a spin. All i can say is wow. I couldnt belive that it owuld make that much difference.
If you dont have acess to a rack easy way is just jack up the front of the car to relive the load off the strut towers when you install the strut bar. It is worth the extra effort.
It makes some sense, but I just keep getting advice both ways from people and places.
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5580821
I would think that lifting the car, letting the struts hang and then fitting the strut bar would cause the brace to undergo compression when it is returned to road height.
From my understanding the strut brace was to prevent the tops from spreading apart.
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5580836
As Eiji said its to stop the struts moving, so fit it when the car is on the ground stationary and they will be joined in that position.
If you lift it up and do it, putting the strut bar under compression, wont it be encouraged to lose its compression going over bumps?
Therefore moving the strut towers??????
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5581774
It makes a lot of sense to do it flat. Esp the if do it up, it gets some pressure on it, helping it move wrongly when go over bumps rather than keep it in the place of when the far is flat.
I'll keep looking for info, but I put it on with the car flat for now, but may need to check it again, as the ground was a little slopey on my drive so it might not be 100% right.
https://www.sau.com.au/forums/topic/346654-front-strut-bar/#findComment-5581856
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
