I just bought an rb26 flange of ebay thats been laser cut out to make my own exhaust up.
The thing isnt flat and the ports dont line up correctly. Yes it was done in australia.
Why cant people take pride in there work and check it out, close is not good enough people.
4 things guranteed in life
Death
Taxes
Work
and
Evil Cnts.
what was the price like though? was it cheap for what it is? if yes, then that explains it.
also was there any chance you had it upside down or back the front that may have caused things not to line up properly?
The price was 59 so its not cheap
But if you pay for something and its cheap does that mean they dont have to make it for the purpose ??
It will not go on back to front or upside down
Yes I have had it up against a stock flange its compared to the stock flange and gasket
Ok well I paid 59 for it and since its cheap it doesnt matter I have to throw it in the bin ??
Clearly its my fault I should have bought something more expensive.
If you bought a soccoer ball from ebay and it turned up square would you be happy because it was cheap
Awesome see even you guys are so used to having people supply you with shit stuff that your happy to accept it now.
  • Nope 1
Buy the items you need from a shop, if it doesnt fit, take it back and get one that does.
You see a shop owner will protect his/her rep on most occasions and you are supporting a local business which is good, as opposed to supporting a faceless profiteer from an auction website. So how much is your $59 flange worth to you now and how much was it to get one locally?
Ya dig?
have you though about modifying it to fit better?
or you could do the smart thing and instead of whinging about it on here, contact the seller and tell him you aren't happy with it, and it doesn't line up, etc, and either get a refund or a replacement for one that does what it's supposed to. send him pics.
this is the reason i don't buy much stuff over the net. i like to be able to look at it first so that if it is shit i don't buy it to start with.
Ive bought random stuff for my car from ebay and all though i havent had any major problems as .Yet everytime i get something it looks like its a factory reject ( you know people work there and things dont pass QC so someone has snuck it out of the bin and sold it) or something that fell of the back of a truck...
For this reason i always try to get things that are at least local so i can view before i buy, however that is easy being in melbourne..Not so easy for people that live in country towns and dont have that option..
I am usually of the opinion that often a quality product second hand is better than a cheap new one..
I got everything for my build second hand locally except for an exhaust gasket for 30$ off ebay...I still have my fingers crossed on that one...
Ebay is a gamble, just like online poker or pokies..
When you blow your cash gambling nobody cares..
What shits me is ebay is setup so you cant complain without a whole lot of hassle and thats what makes it easy for people to sell junk. I think this is the problem that needs to be solved
Edited by Arthur T3
Yeah your right , you dont have much recourse on ebay which is bad. They will make you pay to ship it back which is not worth the effort
There are some good dealers on ebay , like lewis engines etc. I have got some great stuff off them. I expected this guy was the same , alas not so
Ok so I must be a whinger for getting something shit and talking about it here
Man what a pack of wankers you guys turned out to be
Yes yes, we all have good flanges, We are wankers arent we.
You weren't even in the conversation and you joined with that
I guess you left no doubt to your wanker status
well done
  • Nope 1
well done
Why thank you, I'll remember that whilst I'm wanking over my perfectly good flange.
  • Like 1
You purchased something off ebay, that was cheap.
There are plenty of laser cutters in each state that you can physically go down and talk too, ask them about quality, see their work.
I mean come on, "you asked why it was so hard to get good stuff", yet in the same post turns out you purchased it blindly off the internet.
Hell you don't even know if it was made here and the likelyhood it was, is slim. Its common sense.
People answered your issue and told you that you to spend money in most instances to get decent stuff
And then you get all emo about it? Odd
It's no different to buying a cheap materials/fittings for your house or something. Half the time they don't line up or they fail and you curse, takes time to fix and so on.
  • Like 2
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
