Any one played with one of these? what kind of money am I looking at, for a system to suit R33 gtst?
Cheers.
Plug and play with very minor mods ( running map sensor line etc ) is $1395 excluding hand controller but with laptop software.
Cheers
Ken
Wolf 3d plug and play is indeed plug and play
i know its about 1800 for install and tune
the ecu retails for 1395 with a couple hundred more a hand controller
I would normally say ask for SST Steve as SST is worlds best wolf dealer but since your in qld id say you want someone more local - you obviously know where to go in you area.
they are a great ecu for the price.
Interesting Tom ;)
We were told the price we had to quote was $2200 installed and tuned and $2K for SAU/Sil members....
Ken
Guest darrinspencer
Cheers.
I have one
I am installing it in a couple of weeks time
It will be tuned at Bob Romano Performance in conjuction with KP performance (the Brisbane Dist.)
Will let you know the results
Interesting Tom :D
Ken
Hehe its why i said about - by the time you add the controller it is past 2k easily :)
Im sure you know alot better then me seeing as how you do sell it down at hyperdrive :) perhaps i should have added the disclaimer that i know nothing hehe
Still awesome value at 2200 im sure you will agree Ken :headspin:
be very careful with the wolf 3D their product isn't what its all cracked up to be !
Had many problems for a plug and play!
You would probably be in the minority as a lot of them are in Sils and Lines here in WA with some of the 500+ hp GTR's running them with no real issues.
Maybe you got a dud one or the shop doing the work may not be familiar with them.
Tomj , they are good value for the price but $2200 doesn't normally include the controller.... :D
Cheers
Ken
If the unit costs $1400 (rounded up), hand controller $200, installation $0 (so easy to install i can't believe any workshop would charge to do this, provided you get it tunned through them) and tunning $300 max. How the hell do you get $2200+.
I've had the unit installed and running for the past 18 months with no real issues, just a light retune of ideal mixtures. Do a search and chech the previous threads :D.
The unit works and works well :).
Tomj , they are good value for the price but $2200 doesn't normally include the controller.... :)
Cheers
Ken
I dont think they do them for the GTR....
Sorry man but they do and they are a pandp ( if you don't count the MAP/boost line )
Nd4spd ( 600+ rwhp ) has a plug and play in his and ran at Motorvation with it.
Fabs V Spec dumped his Power FC for one and I'm sure Steve can fill in the blanks...
Cheers
Ken
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
