Redirect the exhaust flow to pass through the charcoal canister first? Though you would probably introduce some backpressure via 10mm hoses to the canister itself and negate the straight pipe.
And then into the passenger cabin :thumbsup:
he wants to tune out the smell from a decat exhaust.
the only way to do that is by changing the mixtures, which would alter the motors tune etc. not advisable.
if you want to run decat you will need to wear the risk of $15,000. pretty much end of story.
otherwise you are welcome to lose 3kw and run a decent cat for the price of an extra $400
FYI $15,000 > $400
FYI $15,000 > $400
This "fine" has gone from "$10000", to "$750" (I believe Stao/Hypergear was the one to cop this fine) to now $15000.
I wouldn't be surprised if it were nothing more than a defect notice at this rate.
Also, OP - just run it SO LEAN that the engine won't even fire up. Then you'll never have any exhaust gas passing through the system, and therefore no smell!
I have been of the understanding that it was $15,000 for the last decade, unless times have changed.
It will be a circumstantial penalty, depending on your situation. Yet do you really want to take the risk? And do you really want to leave noobs with the impression they may just get a defect notice?
Obviously it is the owners decision, yet a well known POOR one at that. A few KW really isnt worth the hassle.
A screamer on the other hand :P
Can you still get a fine if your car is Unregestered but driving on a permit? My exhaust is straight through no cat not muffler... just say if i went to a workshop and a cop pulls me over but im on a permit is that ok?
it will be tough to do but leaning it out at idle and cruise etc should reduce the emissions a bit and thus reduce the smell too but basically without a cat you are going to be up against it to change things much just by altering the tune. unless it's rich as all hell at the moment in which case a tune up with a leaner AFR across the board would certainly help. but to be honest if it's a problem then you are better off spending the money on a good cat.
A cat turns carbon monoxide and unburnt fuel to carbon dioxide and water.
It hasn't really got anything to do with the tune unless his is tuned very rich. He can lean the motor out but it will still have the smell of running no cat since the smell is carbon monoxide.
To answer the OP's question in a serious manner, no you can not. Whatever you have read about "EVO's" doing it, you have miss understood.
This.
Agreed you cannot tune out the issue, but you can centainly try to change the mixture so the smell is not so evident.
Either way I think it is a silly idea, just put a damn cat on or wear the risk.
Im not sure about state to state but as a general the car is out of the cops 'jurisdiction' when being driven on a permit unless it is- 1: dangerous to drive, 2: being driven dangerously.
so based on this the decat is fine on a permit...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
