Trent i dont, i didnt feel comfortable asking you for any more help as i understand your a buisness. Im assuming cause i dont have the software that i probly cant do this myself? Im more than happy to send the power FC to you and pay you if you are willing to help out? also if you could leave the basic rb26 map in it for me? as it currently has a tune for 260kw for a big single and 720cc injectors. the 26 going in will be stock for 6 months or so. Pm me if you can help out so we can sort out some payment. Wish i was closer to you id just drop the bloody car off to you and be done with it.
if its going back to stock a simple DATA INIT will load the default maps, AFM ramps and all the settings
obviously you will loose your current tune if you do this, but thats the sure fire way
or do you just need to revert to stock AFM ramps and keep everything else modified as-is?
its a 5 minute task in datlaogit to load the stock AFM ramps
Have a look in the folder that you installed FC Edit universal and you will see there is a bunch of maps that get installed with it. There is an R34 GTR RB26 v8.0 something map there as well. You can use the software to open the map offline and get the data that you need that way. All the GTR maf sensors have the same scale so using the R34 map for reference will be fine.
Edited by GTRNUR
  • Like 2
where are yo located?
i only ask as i am in and out atm. It would take 5mins to make something up map wise and would be happy to do it. how soon could you get it to me?
the fc datalogit base map for the rb26 is based on what octane fuel?
Loading the base map still isnt goin to be ideal. Needs to have a decent tune in it.
+1
The base maps are enough to get your sensor calibrations correct and to drive off boost, but you certainly couldnt drive it on boost.
One other thought... If your going to use twin GTR maf sensors on an ecu with only one MAF sensor input you are going to have a tune stability issue. There is always some difference between the output voltages of both sensors.
The GTR ecu uses a mathmatical calculation that adds the two voltages (maf sensor values) together to work out the actual airflow. You can not do this with the RB20 pfc so the active load point will be off on occasion by at least 1-2 load cells.
Tieing the two maf output signals together will not work. Their values must be read independantly and then processed. Your only option will be to use a single maf sensor, and have a single air input path to the engine.
Edited by GTRNUR
  • Like 1
i was always planning to run the standard ecu, i just read something trent posted that i thought opened my options up a bit. if that much of a problem i will just run the stock ecu.
I was always planning to have it tuned after the power fc install. just assumed it wouldnt run with rb20 tune it... thus asking for the stock 26 map
ive dioded them up in the past on 1 car, not ideal but from a tune and driveability perspective you would never know. maybe i got lucky but as long as the afm curve is smooth it should be ok.
other option is to run one z32 in the cooler pipe.
Cheers guys. I knew something was different about the 34R PFC, just couldn't quite remember what haha.
Also, worth paying that little bit extra for the new PFC and EL hand controller? Will that fix the missfire that the 32Rs get with the PFC?
and the physical loom plug is different, so even if you decide to be super crazy and pin swap, the physical plugs are different
nah they are the same.
PFC negates nats
and cas wires need swapping.
EL Hand controller is the best marketing rort since since Y2k compliant calculators..... i hate them.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
