Hi guyyys and Grrrrls,
I had stupidly decided to purchase some new rims for my car which are Work Meister S1's:
20 * 9.5 + 25
20 * 8.5 + 25
Now the rear fit snug as a bug in a rug, just teasing their lip out of my lightly pumped guards.
Issues arise with the front however. The rolling diarmeter of the rim seems too large for an R33 to cope with.
The tire in the pics is a 245/40/20... so I am intending to run a 225/30/20 with some stretch to pull the rolling diameter back abit. That said, the 245's on the rim are worn to the belts and therefore I am skepcital of how a 225 will go with full tread, considering this worn out 245 still rubs.
Now, I was considering a 10mm spacer to pull the inside of the tire away from the control arm, AND a 225/30/20 with abit of stretch in the side wall to increase the gap. However, I'm not sure it will be enough.
Has anyone else run into these issues with stupid 20s? Suggestions? Does anyone know if aftermarket control arms are available (I had a quick look, but didnt see anything)
Pics of my problem....
https://www.sau.com.au/forums/topic/347707-20-inch-wheels-on-r33-work-meisters/
dont run 20's? ;)
seriously tho, spacers are gonna be your only option....
if you go 20mm bolt on up front you'll have clearance and 30mm bolt on rear then pull the guards it'll look even again... this will take work and cost a lil :/
Hmmmm. It appears 225/30/20s only increase the rolling diameter by 11mm over the standard 225/50/R16 rolling diameter of the 33. If I add in some stretch and some spacer-age... and I think it might just fit.
Haha I know this will cop "dont put 20s on a 33"... but they came up so I snapped em up. Sort the fitment out at a later stage :P
20 * 9.5 + 25
20 * 8.5 + 25
Judging by the pictures you posted and the overall diameter of your current tyres you shouldnt need bolt on spacers to make the front wheels fit.
Here are the approximate overall diameter's of the tyres you have and alternatives that could get you out of trouble (factoring in tread depth which is usually about 5-7mm depending on the tyre).
245/40R20 - approx O.D: 704 - 705mm
245/35R20 - approx O.D: 679 - 680mm = -24, -25mm (compared to 245/40)
225/35R20 - approx O.D: 665 - 666mm = -38, -39mm (compared to 245/40)
225/30R20 - approx O.D: 642 - 643mm = -61, -62mm (compared to 245/40)
One thing you will have to be aware of is that as a general rule the lower you go in sidewall, the lower the tyre's load rating and if the load rating isnt equal to or higher than the manufacturer's spec then you can be defected or if you have an accident your insurance can be void... So make sure you check the load ratings before fitting new tyres.
I hope this helps :)
P.S - Love the Work Meister S1's! :thumbsup:
U can also get defected for having a total diameter over 15mm over stock so you pretty much can't win with 20's. I'd prefer to have the correct outer diameter than the correct load rating.
Should've got 22's for your 33 :P
On a serious note though, grinding down the upper arm worked for me, had the car pretty low and it scraped on full lock. Another option is to just get yourself some adjustable coilovers and raise the front up by 10-20mm. Won't have a huge impact on the look of the car.
Spaces draw unwanted attention so I'd steer clear of them.
I do have Teins in the car... so once I get the wheel clearing I will play with ride height to make em not scrub on the guards.
I am hesitant about griding the control arm. I know in reality its an easy fix but its abit of a last resort for me.
I will run 225/30 tires on the front, and I am hoping this will provide the clearance I require. Will keep you guys updated!
i personally wouldnt touch the control arm. who knows how much that is going to affect the integrity of the arm + what if you get defected? would they knock you for that? could mean a new control arm...
thought i wouldnt be able to say this but it looks fkn sweet tho mate, tuff as nails
Thanks!
Haha yeh everyone hears 20s and thinks "GAY".
Thats ok i generally do to. But I must admit, these 20s I couldnt resist. There is something stupidly attractive about the proposition of black 20inch meisters on my car.
Im going for a new look, so the wing will be coming off and replaced with some carbon fibre touches here and there :D
20s look stupid on the front of skylines the lack of tyre sidewall and the raised hieght is ridiculous..
Now if your were to pick up some 18s for the front,it will make your steering easier and better, it will make your your frontend lower giving the car a mean rake with the front being slightly lower than the rear and generally all your problems will be solved and your car will look tuff as balls..
Thats my 2c anyway ,if you wanna keep your stupid 20s on the front then i have no further advice..
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
