Guys, I have been reading this thread alot actually as I went in Sam's 305rwkw 4dr 32 and these turbos are very similar to the td06 he ran.
The power with these is very impressive, while I still enjoy my Garrett, I cannot get outta my mind the td06 copy simply when I went for a drive with Sam.
Essentially it was like a light switch, all of a sudden this absolute enormous RUSH and in 4th we went sideways. He was laughing his ass off, as was I... while screaming.... the Garrett by comparison is extremely linear and pulls harder and harder, but sometimes I like that instant smack of boost.
I've spent too much on my setup now to change, but I assure you that td06 copy DID push 305rwkw
Make up your mind, you often chastise 56trim GT3076Rs for 52trim ones - they are barely different in size. If the compressor affects response that little, 52trim GT30Rs are redundant :)
That is all oversimplified anyway, the compressor has a lot of affect on how boost threshold is achieved - loosely speaking the exducer is responsible for accelerating the air, the inducer is responsible for drawing it in.
You can actually make a more "responsive" turbo by having a larger sized exducer (fine balance between extra mass and extra "throw" off the tips which is where extended tips come into play).
Same goes for Garrett GT series turbines, they are often physically smaller for the equivalent than Mitsi/Borg turbos but they use a less abrupt blade attack angle through the turbine, meaning they are more of a high speed turbo. Lighter, but don't necessarily respond as fast to low speed gases for the equivalent size... so give or take a bit a Garrett GT series turbine would be normally the equivalent in response and flow to a larger say Borg Warner one, for sake of arguement.
I could go on for fricken ages, but the gist of what I'm saying is don't assume that all things are comparable just by mm measurements of a pair of wheels on different turbos.
Obviously size and trim are only a part of the equation, I know, as there is the design involved aswell. Be it so simple why would new technology arrise? We have always had control over size and trim, its not like it takes 30 years to think of a new size and trim combo.
What I'm saying is, while I have bastardised and simplified the terms to a ridiculous extent, I realistically just wanted to put forward that I have lost faith in simply dropping compressor size to make up for a lack of response. I am more so looking towards matching the largest and most efficient compressor to turbine as possible. That being said I still like the 52t 3037 combo better than I do the 56 :P
I also would like to put forward that my hunt is not for the most PSI at the lowest RPM but actually the broadest powerband within usable RPM limits, irrespective of boost pressure acheived at any RPM.
I have never read many good things about the TD05-20G. Seems to be a bit of a mismatch in wheel sizes. The TD05-18G is the way to go it seems, the 20G is just too much compressor to be spun by the little TD05 wheel....also on a plain bearing turbo running a mismatch of wheel sizes means you end up with higher bearing loads as at rpm as the axial load increases...or so I read
But the TD06-18G could be a good thing. I have been told the TD06 wheel is a good thing and its the 20G compressor that makes the TD06-20G as laggy as it is. So a TD06-18G could be a good thing, good sized turbine so that you can get good boost and flow without too much back pressure and a light little 18G wheel that is good for 240-250rwkws. I think the problem is the shafts are different diameters
car is booked in for a tune next monday, finally ahha. Somthing i noticed is defferent between my T67 and simon/batteries, mine had a bullet type nut on the compressor, came like that from factory...
Well now I'm just jealous! haha
Is your turbo ID tag the same as mine, as in a Kinugawa tag with T67-25g as the model?
Good luck with the tune :)
how jealous? hahahaha. seriously, this is how it was when i got it.
and anyone in vic that might be attending the show n shine at carribean gardens on sunday the 22nd of may, i should be there with the car, i might be entering with another club just for the hell of it, not for trophies, just for somthing to do.
as for the tune... it will be interesting to see, especially auto with a powerFC, ive since been told that powerFC's werent made for autos.... makes me wonder if the ecu is a powerFC ive never looked lol, thats what i was told it had when i bought it. i know its not a stock ecu because i have a dyno sheet from the previous build from the previous owner, oh well might pull it out tomorrow and double check it.
the guy thats tuning it thinks we should easily make 300rwkw on 17psi without pushing the engine 2 hard. its being road tuned apparently.. i dont know much about the tuning side of things, just the mechanics of it all. then cross fingers with some slicks, + the auto, im hoping for a mid to low 11 as simon has done.
btw simon what oil are you running in your engine, i need to throw in some new stuff before the tune. im running Motul Turbolight 10w-40, but ive been told i should go up to a 10w-60. any thoughts?
cheers.
Edited by OMY31T
hmm Im not too sure about the consistency of Mr Kinuagawa.
My right angle oil line feed is different to both of yours.
Initially I received the wrong V band flange but I contacted him and I had a new one sent to my door inside a week.
He also had 2 different listings for the T67 on ebay with one being $50 cheaper, I messaged him about this and he said they were exactly the same...
nothing major but something to be aware of if you buy one.
Good luck with the tune OMY31T im interested to see your results with the stock plenum vs Simon's with the "freddy".
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
