so i have sent my address, and once i recieve some, ill let u all know, get some details off the poeple that want them... simon, battery, arthur.. and others, depending on how many come in the mail(i asked for around 10) :D
This ever happen?
Plus Battery any chance of getting some vids up of performance? Would be keen to see some 3000rpm pulls in 4th to see when you get 15psi (same as my video) :)
One is internal gate one is external gate?? . go the t67 btw
theyre both internal gate.
the ext gate one i posted was just for reference to see if anyone managed to fit it in low mount.
T67 is a beyond 300kw+ turbo and is way more then i want so the extra lag is not needed.
These days it seems increasingly hard to beat a hypergear turbo. These SS turbos are nuts.
The kando's are actually better for more specific applications, like the T67 for big power like what Simon has shown. The 20g is yet to make its mark with anyone, we are still waiting on results from a couple of members (previously including me). Jap dynos have shown 12cm 20g's to crank close to 300kw and stand up stronger than a 3071.. Now we are working with 10cm housings which really have no restriction in seeing 300kw, so the results should be interesting. Certain well regarded tuners have also shown interest in results from the combo, it should be good.
Downside is you need a gate, whereas with HG its all bolt on. I think there will always be tradeoffs between the two, and Stao is limited by the internal gate.. Yet if working on a budget they are both viable, however if stealth fitment is a desired option, the tradeoff (expected to be small) to a HG would be worth it.
What if someone tried one of these?
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=49179-04100&Category_Code=
That'd probably give things a bit of a shake up - especially if FP were extra nice and put one of their 68HTA cold sides onto one :)
have anyone here tried this?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-Nissan-RB25DET-R33-TD06H-20G-/270789860335?pt=AU_Car_Parts_Accessories&hash=item3f0c555bef
would the 12cm be too laggy on a RB25 NEO?
looking for a unit that can be low mounted as i want to avoid the high mount path.
also cant tell the difference between the two apart from the $200 price difference?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-TD06H-20G-12cm-T3-RB25DET-/280720132071?pt=AU_Car_Parts_Accessories&hash=item415c3947e7
target goal is anywhere from 290-300 (more is a bonus) i believe the t67 that simon has would be too laggy for me, so the TD06 would be ideal.
RB25DET NEO
built bottom end
has all supporting mods already.
PULP only, no E85 here
currently running a twin turbo setup but looking for more power and just weighing up costs for upgrading twins VS single big low mount. (So far the low mount ends up cheaper but it is for the turbo to be high mounted which im trying to avoid)
ideally i would like this one but not sure if it'll fit in low mount position?
http://www.ebay.com.au/itm/Turbocharger-Kinugawa-TD06SL2-20G-w-T3-V-Band-Housing-/290598627474?pt=AU_Car_Parts_Accessories&hash=item43a9072892
the last one u listed is the one I have its a tiny turbo and will low mount very easily with a 10mm spacer. Plus you need to plug in a gate somewhere.. i got it because apparently the internal gated ones are no good..
If i ever get my car back from the panel beater I will fit it and tell you how much power it makes..
btw I got it for 700 as well so make em an offer ;)
The actual trust 20G for a 1JZ comes in a 12cm job, which is what i based my decision to get one from. They did not appear to be laggy yet I was dubious.
For the price of the housing swap I think its worth a go. There is a version with the rear housing uncapped and a 5 or 6 bolt outlet (not the single exit 3 bolt outlet).
However from what I have seen the trust IW item was the 3 bolt item (with the WG flapper not direct flow).
http://store.forcedp...&Category_Code=
Ive considered these time and time again... The front housing on that one is the trust spec housing but no idea what rear housing its got. If its 10cm its probably the item to have.
I am however even thinking a TD05H-18G would be good (Y) they are not shy on power even in small housings. Get one in a 10cm and your laughing.
This ever happen?
Yeh im sooo lazy... I tested a while back but i can't remember the results!
Picked up a greddy gauge with peak/warning to replace my stuffed HKS so ill hook that up soon and set it at 1 bar then test it again.
As much as I hate to say it the Hypergear things are starting to look pretty attractive if your after Internal gate options.
i ran a ext gate right off the rear housing on my old turbo, might do it again if the td06 can be low mounted - appears it can be according to ARTZ post (look forward to pics when u get your car back mate :D)
perhaps i can get a custom low mounted manifold with ext gate opening on it.
ideally id like it low mounted and to have near 300rwkw.
hypergears do look very good however not many ppl are pushing over 280 with their turbos on PULP so its hard to see some decent results with the ATR43G3 apart from Staos personal development car.
300rwkw and low mounted would be the perfect setup imo :D
the middle one is ext gate? . Wouldn't you rather a turbo with plenty of headroom for more power instead of ringing its neck to make the power? :thumbsup:
GT3076 with internal gate off stock manifold?
No because that means extra lag for no good reason?
Edited by Rolls
cant get the 3076 for $900 now can ya :P
my ideal setup would be the td06sl2 10cm on a low mount custom manifold with ext gate.
the hks cast low mount manifold would be perefct but theyre rare...
wow, i just found out that 6boost do the low mount custom jobby with ext gate. WIN!
Td06L2 10cm t2 housing pulled 302rwkw today at the shop, all round nice setup.... for 900 hucks.
got mod list & dyno sheet trent?
More info PLEASE! I'm prepared to beg.
Graph too if you can. Thanks in advance mate :whistling:
Yeah I nearly bought the one (HKS mani) in for sale the other day cause I have an old HKS gate to suit, probably should of but i dont have alot of faith in second hand cast parts I cant see before I buy :(
now I will have to weld it onto the housing ghetto style too, doubt i can afford the 6boost low mount atm..howmushizzit??
Actually if i sell my old turbo..hmm
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
