yes, but hazzard a guess I would say 280-290rwks max on 98.
would have awesome snappy power on a 25 though
yeah thats what im hoping, if you have to get a new manifold though it would be the 67 for sure..
I tried to fit my t67 on the stock manifold just to see if it would fit but it was hitting engine mounts and A/C lines looked like alot of work and bordering on impossible.
Are you going to plumb the gate back into the exhaust?
See what happens..might try a screamer initially just cause I never had one before..lol.. Is yours..??
there was that T67 that had the smaller comp cover...they dont have any for sale now..
yeah so keeping in my mind on an rb25 you will ideally want the 10cm(.73) rear on all EG variants..all you really need to know is 20g for low mount or 25g for top mount..everything else isnt really too important..
Just trying to simplify it cause there is just too many variants...
It will be great to see the 20g and a gate hung off the stock manifold, with all due respect I think it will give hypergear a real run for his money.
It must be said tho, if you are looking for the simplest street orientated option I would stick to the HG. Being externally gated and proven capable of very high flow I would want the Kando for anything that will do some serious track time. No disrespect to HG but I would say for a hard tuned motor the Kando's will be a little more resilient to EGT.
Yeah that's why I'm going to give it a shot it going to be street driven but also taken down the track a fair bit
Yeah thats the thing, the HGs are great these days but we have seen they do get hot. Im confident the 20g will give the current good HGs a very good run for their money for spool/power but will definitely handle the heat a lot better.
The benefit to the HG is having it bolt up to most of the expensive stuff (manifolds and dumps).
GL, I rekon you will have a kick ass setup.
Haha yeah DVS jez kit a off the shelf kit I couldn't get a off shelf kit for rb25 in a Vl so I bought a vlt kit and drop saw and away I went made my own
Gtscott how'd you blow microtech wired up wrong?
You need to be careful with the bloody thing, its pretty weak electronically. What I did was short the ground on my VCT solenoid which is plugged into the vactory ecu. This caused a 12v spike to the stock ecu which is only earth switchable so the stock ECU spiked just about everything and blew its fuse.
When the stock ecu spiked it send a spike down the CAS trigger which the microtech piggyback's onto which fried my injector drivers.
I now have spark but no fuel. Microtech were pretty good about it though, should be able to fix it under 200 if I cant fix it myself. I think its likely to be the earth track for the injector drivers so ill just solder a wire in myself (havent opened it yet).
Careful not to over voltage any of yours inputs coz they do not like it lol.
probably a good thing, microleb for the lose.
ROFL imagine an army of microlebs! Shu Microcuz's! (nobody take offence im a big bad dirty wog myself)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
