love the thread it a long read but jam packed with good info...........quick question
hey i got a 2j with cams,upgraded valve train,wiseco's,manely rods head ported ,link g4 etc................i had a pair of kando td05/20g turbos which i sold brought them to run on a stock 2jz now ive built a motor im looking at getting the 800hp plus mark.........what do you guys think about a pair of td06sl2/25g with 4 in cover and a 8 cm rear turbo's i can change housings to 10cm/12cm there are option in rear housings................be to laggy,will i get 800-1000hp out of those td06sl2/25g's
25g x 2 will be too big IMO for a still 3l jz unless you're turning 9k rpm
Td06h-20g with 8cm rear will be monstrous on e85 turning the jz to 8000
Might not quite make 800rwhp. But will be bull shit fast
Also how did the 2j go with the td05-20gs?
Full boost / power erc?
im not using the td06h/25g im using the td06sl2/25g
's
never got them running i changed my mind and wanted to build a motor...............the sr boys are only making 220kws with these td05/20g is on par with a gt2871/6 nearly most 2j boys pull with gt28's are 420kws with ripe fruit on the motor
i got 272 cams,shimless buckets etc it's built to rev
Edited by stocker
here are the compressor and turbine wheels for the td05/20g and the td06sl2/25g not really that much of a differance in them few mm's
TD05/20G 3IN ANTI-SURGE COVER
Compressor wheel: 52.5 / 68 mm (20G)
Turbine Wheel: 49.3 / 56 mm (TD05H)
TD06SL2/25G 4 IN COVER
Compressor wheel: 60.5/78 mm (25G Wheel)
Turbine wheel: 54.1/61 mm (TD06SL2 / 11 Blades)
Edited by stocker
Speaking of cams earlier I'm going a td06h 20g 10cm on my rb25 would poncams be worth it or would stock cams be my better option I was as much response as possible with as close to 300kw as possible even a tad more if I could
Im honestly not sure why your chassing the TD06H though, what we know suggests the L2 is going to be more responsive and able to max out the flow of the 20g with ease.
Dont forget Simon's T67 uses the same rear wheel as an L2, no flow issues with the 10cm....
A fair while ago there was a topic by STATUS with a poopra that ran twin TD06SL2's and I think made a tad over 1000hp
Do it, it will be a monster :)
Run dual 6cm L2 for around 800hp or dual 8cm for 800-1100hp on 98.
Ive tuned a few pairs on similar setups to yours i prefer the 6cm as it makes it very liveable down low, the 8s are ballistic.. forget 10cms.
thanks for the reponse and support guys..............lots of the poopra guys dont use these kinugawa turbo's think they are crappy ebayu jobs but are quiailty items...........where would i get a 6cm housing from that guy eiji from kando only dose a 8cm thats the smallest in their range for the td06sl2
would you have a link to the twin sl2 supra thread
has anyone used the kando/kinugawa td06h or td06sh its bigger then the sl2.........sl2 is only slightly bigger then a td05 ........i'll be using the 25g compressor wheel with 4 inche so what 2 will net me the 1000hp
here are the specs
here is the td06h
Turbine wheel: 58.8/67.2 mm (TD06H / 11 Blades Inconel Wheel (TD06H4)
here is the td06sl2
here is the specs for the td05
Turbine wheel: 55.8 / 49.1 mm (TD05H Inconel Wheel)
discount the above td05 turbo's as i ruled it out already
Edited by stocker
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
