10x1.25 iirc and about 65mm long I am told
Yep. Although with a 15mm spacer I used 57mm studs and they have plenty of room, so unless you need a 20mm spacer I'd say 65mm would be a bit long. Unless the Kando flange is thicker than the HG flange, I don't know.
hmmm
will send pm in a min
not ready to buy yet
will buy one of these first
http://www.summitrac...-2046/?rtype=10
to be 100% happy on the way it fits
Your going to spend 400 bucks on a foam LS1 to see if it fits?
LOL
dude its a commondoor motor... Why not go on a common forum and look for a blown one for $50
thanks guys
ARTZ, did you use a 10/15/20mm flange spacer?
found that ARTZ used a 10mm spacer and it "just" cleared.
might go 15mm for peace of mind.
so new update part list:
10-15mm spacer (up to you what size you want to get) $30
new exhaust manifold studs & nuts x12 ea (if needed) $110~ (nissan) or generic stuff from local exhaust place ($50~) - this is optional but if you break a stud or round one, you will need to replace them but it is a good thing to replace them all anyway and is cheap insurance that your studs won't break or round.
Dori you should do a DIY thread with pics for a 20g 10cm and document your results. Itd be nice to see the bare minimum done to fit one up, and documented for all to see.
good idea,
i shall get started after the new year once i get all the parts.
cars booked in for 16th Jan.
thanks guys
10mm
jeez man i have documented nearly my whole build in here...
what would u like that i have not provided :(
BITCH!!!
Car went great at drifting yesterday.
Only issue's i had was a busted radiator from the fan coming in contact (.5mm contact) , i popped the cooler pipe off twice. And i need a tighter diff centre. The GTR one just kept going open.
Other than that was a great day out. This turbo is very nice to drive with. On song hard by 4000rpm all the way to limiter at 7400. I will definately be fixing up the vct and tuning it to 18psi. At the moment with no boost controller and a tiny 35mm turbosmart gate it starts at 11psi and climbs to 17 by redline, starts getting crazy at 17.
I'll post up some incar vids once i get them off the GoPro
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
