OK more or less the same CFM of air (with a resultant HP) will have a higher EGT with the higher comp.
The TD05H-18g Jez tuned for me recently on a 9.5cr motor would start pinging once we hit 16ish psi. Pulling timing wasnt helping..... I have a feeling the 8cm IWG TD05H was just a shit balance when driving a big compressor on a high comp motor. It comes on boost very early and strong, just didnt want to take the boost.
It did make 207rwkw @ 15psi on a Mainline dyno, but hey we wanted more :whistling: It did not appear to be an issue with the way it was being tuned as I was on site watching timing and fuel trims being altered to combat the ping.
Was it super responsive with the high compression ratio of 9.5?
Jez can vouch, it is a very responsive setup.
Made 530nm @ 4200rpm and 207kw @ 6000rpm.
Im very curious to see what 10:1cr does, my motor is also a VCT model.
Haha come on man.
Still running besides the 150ml of oil in the sump after the sandwhich plate snapped off the block. New bearings and sat on limiter all day at wakefield.
I honestly havent checked the inj duty. My tial 44 arrived today so hoping to dyno it next week on 20+psi then off to the drags.
Nah sydney is horrid for E85, will be tuned on 98.
Thus my EGT concerns lol
Ah yes i see haha.
A mate and I used to own turbo commy V6s (yes flame on lol) and he had a stock ecotec with 9.2 compression and a GT3076 0.82 turbo. Car was fantastic made between 250-280rwkw depending on tunes and was super responsive.
Then he blew that engine and had a forged one built with 8.0 compression as per the advice of the guy building it. I said thats stupid but he trusted other guy more than me :(.
Car lost a lot of response and struggled to make 250rwkw with the turbo running hard.
I told him that he needed a GT35 and lots of boost to get the low compression engine in its element but he didnt want to loose more response. He ended up getting over it and selling it.
The higher the compression you can safely run to make your power level taking fuel into consideration is what I reckon is the best, especially for a street car.
Then I read about people putting turbos on stock M3 engines that are 11.5 compression with E85 with crazy results.
All this E85 talk :( , i'm getting tempted , i wonder what it costs for a 44gal? . Anyways , i picked up my turbo from the post office today :D i can't wait to get it all fitted , just a quick question about ext gate positioning , is it better to mount it off the exh housing or off the manifold??
I have not seen that many cars running E85 day to day. Those that I have seen running normally take forever to crank and idle like cops until warm etc if they dont foul plugs. Is there someting in the tuning of them or thats just the nature of the beast. Certainly I am yet to see an E85 powered car crank to life like on 98 and not splutter blowing sweet smelling fumes out the exhaust.
Not saying this is how it has to be...just that those I have seen have put me off it as there must be a trick to getting them nice for day to day
Mine starts identical on both E85 and 98 whether cold or hot. Although Trent from Status has tuned a heap of cars on E85 so has had a lot of experience with it. But the point is its definitely possible. My mum borrows my car and hasnt mentioned a thing lol
Right , i think i might make another thread on it soon :ph34r:
ok after a bit of a google search , E85 isn't the best choice for me , but the united 98 i was talking about a couple pages ago seems like the best compromise . link http://www.unitedpetroleum.com.au/fuels/premium-98
Edited by toffy
You can't get E85 in the UK, well you could at about 8 petrol stations then it was stopped.
There is an E5 I think though, it is the same nominal octane as the Shell 99 I use. Would E5 be better than a 99 RON (which has no ethanol)??? Both are 99RON.
you would have to find out what the RON rating is of E5, in Australia the E10 was/is a 91RON fuel unless advertised as a Premium 98 with Ethanol which is a 98RON..
I would go with what ever has the highest RON rating
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
