Artz has convinced me to go highmount, pointed out a few things i hadnt thought of etc.
Im in Bunbury WA, and there isnt to many fabricators down here who like to do anything to "out of the ordinary"
So will hopefully start getting it all together soon.
All the good boilies in bunbury I know from martins and kordt get worked to the bone so they tend not to do cashies but let me know if you get stuck and I will see if they are keen.
Hahaha yep.
Got some great results but car has really bad comp surge coming onto boost. Tried a few things but 11:55pm finish was enough for me last night.
Before we touch the tune up again we need to get the vtc working.
And sort out why it comp surges so drastically on higher boost at low rpm. Hammers after that
Sounds awesome!!! Everyone loves a bit of gate :thumbsup:
Bet your glad you were forced to take it in early now eh? Makes up for the weekends bad luck :P
What is it making? Close to expectations?
Better than he expected once we opened up to screamer. When it was plumbed in it was limited at 250ish kw.
Needs a bigger pipe outletting from gate
Haha AWESOME! i thought the goal was conservative :thumbsup:
I actually thought running a screamer had a negative affect for some reason... Thoughts??
BIG THANKS TO DVS JEZ & BSA for all their work! highly recommended to anyone in NSW for tuning and fabrication stuff, they'll sort you out :thumbsup:
it was a late night but i was very happy with the results, didnt get home until 2am but was well worth the drive!
for some reason, it wasn't liking 21psi and it was surging, gonna try a anti-surge front cover and go back for more, as stated by Jez, sort out the VCT and aim for more. it definitely hammers on the road >_<
PS: plumped up gate = POO
MATT; open up that screamer!
Hahaha Ill drop my wheels off to Craved Coatings one weekend soon and give you a call to see if i can get a run with you so motivate me a bit more :banana:
That looks like it comes on hard!!! And impressive result considering the boost, BEST thing you did was take it to a decent tuner, your last guy will get the flick from now on i hope? :glare:
Good result mate! :yes:
Not sure on bigger pipe as it fitted the tial vband very tight can only try a different merge style I think
:cheers:
for some reason, it wasn't liking 21psi and it was surging, gonna try a anti-surge front cover and go back for more, as stated by Jez, sort out the VCT and aim for more. it definitely hammers on the road pinch.gif
FAAAAARRRK THAT MAN...thats freakin awesome, I thought you might struggle to make 270rwkw, man that is a killer result! ! There is no way I'm going a HG or Garret now, it does hammer on the road right?? ! ! ! Big kudos to you guys man.........:cheers: :cheers:
PS - thats with a screamer not plumbed back hey - bit worried there..
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
