look i dont go that way jez, but any customer with a big head is only going to hurt on the way in.
thats what i tell my girlfriend anyway.
Not to be rude but um... you just said said your GF has customers with big heads that hurt on the way in....
I realised after I posted that I left myself somewhat vulnerable there lol
Good pick up.
well it finally started but I could only find a crappy peice of tube to connect for the Idle valve and it kept kinking so it would barely idle. But other than that about friggen time.
Nice work! :woot:
Did you use the tie wire with that beanie, or just left it sitting there?
I dont know if anyone can answer this but will this (see link to what i have bought)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=270967679078#ht_2148wt_1185
Work with my turbo like this (has the V band in the middle not with the bolts)
http://img.photobucket.com/albums/v416/razor911/04022011611.jpg
This is a hard one to describe, but im confident its the right housing.
if you think about it, just coz the CHRA can be v banded, it doesnt mean you cant machine a bolt on housing to press up to the CHRA and work.
im pretty sure the kando CHRA's are direct copies of the MHI items, and many of the housings are direct copies of the MHI housings also. Yet these T3 10cm housings are definitely custom, and im sure it is them that is different to a normal housing and are machined to have the v band chra slot in and then have a bolt on piece press it in.
Simple logic to me!
Nice work! :woot: Did you use the tie wire with that beanie, or just left it sitting there?
I used a spring on the dump side of the turbo. The other side was awkward to get to the clips and I just wanted to know if the bastard would start lol.
Urt. Did u wrap the entire manifold or jus cyl 1&6?
Hey Jez, nah I did about 2/3 of the manifold, the whole Ext gate dump and about half of the turbo dump. I had to remove a bit on the manifold to get the nuts onto the studs onto the flange, I might fix it later but at the sec I just wanted to know if it would start.
I reckon I did alright for a "pen pusher" with soft paper handling hands as my mates would call me.
Edited by urtwhistle
Simple logic to me!
Good point. Only way to find out is take if off and inspect.
I took the POS for it's maiden voyage. and all I have to say HOLY S**T BALLS. These turbo's sound like jet engines with the surge slots and wow I didn't expect it to have masses more bottom end then my old turbo esp when it's bigger. MUST GET TUNE ASAP!!!!!
Awesome!! Can't wait to see the results of a tune, but glad you are happy with it... Love the spool sound, haven't heard a Kando yet but can't wait too :D
Thats sick man! I like that TD07 front cover, Im of the opinion a larger front cover can be a really good thing on a turbo that size/spec.
Looking forward to your results :)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
