look i dont go that way jez, but any customer with a big head is only going to hurt on the way in.
thats what i tell my girlfriend anyway.
Not to be rude but um... you just said said your GF has customers with big heads that hurt on the way in....
I realised after I posted that I left myself somewhat vulnerable there lol
Good pick up.
well it finally started but I could only find a crappy peice of tube to connect for the Idle valve and it kept kinking so it would barely idle. But other than that about friggen time.
Nice work! :woot:
Did you use the tie wire with that beanie, or just left it sitting there?
I dont know if anyone can answer this but will this (see link to what i have bought)
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=270967679078#ht_2148wt_1185
Work with my turbo like this (has the V band in the middle not with the bolts)
http://img.photobucket.com/albums/v416/razor911/04022011611.jpg
This is a hard one to describe, but im confident its the right housing.
if you think about it, just coz the CHRA can be v banded, it doesnt mean you cant machine a bolt on housing to press up to the CHRA and work.
im pretty sure the kando CHRA's are direct copies of the MHI items, and many of the housings are direct copies of the MHI housings also. Yet these T3 10cm housings are definitely custom, and im sure it is them that is different to a normal housing and are machined to have the v band chra slot in and then have a bolt on piece press it in.
Simple logic to me!
Nice work! :woot: Did you use the tie wire with that beanie, or just left it sitting there?
I used a spring on the dump side of the turbo. The other side was awkward to get to the clips and I just wanted to know if the bastard would start lol.
Urt. Did u wrap the entire manifold or jus cyl 1&6?
Hey Jez, nah I did about 2/3 of the manifold, the whole Ext gate dump and about half of the turbo dump. I had to remove a bit on the manifold to get the nuts onto the studs onto the flange, I might fix it later but at the sec I just wanted to know if it would start.
I reckon I did alright for a "pen pusher" with soft paper handling hands as my mates would call me.
Edited by urtwhistle
Simple logic to me!
Good point. Only way to find out is take if off and inspect.
I took the POS for it's maiden voyage. and all I have to say HOLY S**T BALLS. These turbo's sound like jet engines with the surge slots and wow I didn't expect it to have masses more bottom end then my old turbo esp when it's bigger. MUST GET TUNE ASAP!!!!!
Awesome!! Can't wait to see the results of a tune, but glad you are happy with it... Love the spool sound, haven't heard a Kando yet but can't wait too :D
Thats sick man! I like that TD07 front cover, Im of the opinion a larger front cover can be a really good thing on a turbo that size/spec.
Looking forward to your results :)
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
