It wasnt known till last week. Too many variables still.
I pitty tuners! Especially you :) It seems so many cars get given to you and they are just loads of problems and so hard to get right :( Will be interesting to see if you can get results that give a clear indication of whether the anti surge housings hurt performance at all.
My kando t67 antisurge has drilled holses and a machined slot, i see no reason why this would work any different to HKS/turbonetics style antisurge?
Did DORIs home brew anti surge just have holes or did it have a connecting slot to the front of the compressor also?
LOL yeah i got the Ryobi drill out and went to town with the housing
Hey I'm new to sau been on ns for years
Well ok my set up
Rb20 in s13
Refreshed motor new rings bearing metal head gasket cleaned block
ATM it's running stock turbo and running gear
I want to go td05 18g for response
Have been told to run td06 20g but I don't need or want that much power
Has anyone running a td05 18 ex gate ?
The power I'm after is 220kw
I'm going to be running
550 injectors
Z32
Stock manifold with 38mm gate tail welded on
Niss tune
What kind of power should I get?
I want tge power and response for drift !
-Colin
For 220 and good response why not send the stock RB20 turbo to hypergear?
He could easily make you up a turbo to suit. Best of all, it would bolt back into place where your one is now.
I think he charges $960 for that service and the other parts should all be off the shelf. no external gate, no big costs etc.
I'll buy one if some monkey shows some half encouraging results haha
i'll be a monkey if somebody gives me money :D
wouldnt mind installing an EGT sensor which means turbo out, maybe Stao can do me a billet core for easy swaps..but yeah..no $$$$ atm...
td05 on an RB20 has been covered within the last 20 pages, you could read the thread that we all put a lot of effort into and do it some justice...
advice still stands @ 220 = highflow. highflow is still a brand new turbo, just with your old housings. that way your brand new turbo bolts back into place where the old one was.
Now that I am actually making some progress and have some idea when this thing will be done, thought I should give an update on my build. Here is my setup:
Stock RB25 in an R32
Kando T67 10cm on a 6boost manifold
Tial 44mm external gate
Freddy Plenum
Bosch 1000cc injectors
Link G4 ECU running E85
Going to Scotty's next weekend for fabrication of the exhaust, intake and intercooler piping and have a tune booked with Trent at Chequered Tuning September 3rd.
Car has been off the road since SAU Nats last October, so to say I am excited would be an understatement.
Freddy Plenum
Cool, I will have another GTSt to play with :) Keen to see the result with the R32 gearing
Already have r33 diff ratios and putting a 25 box in as we speak after losing reverse on the way home from sau nats. so no 32 gearing
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
