I'll be on 4XKando power soon with my upcoming projects.
Yet to receive bad service.
Have also ordered a multitude of spares like lines, hoses, actuators, manifolds, dumps and other stuff from him and have zero to complain about.
for Ron: just remember that the 20G was always intended as a cut price option to a HKS GTRS, it was just lucky we also found they packed more power. You can reference this earlier in the thread.
I do like your plan though, low mount for the present and later T67 highmount when ur ready with minor adjustments to your gate off the housing and existing dump. :thumbsup:
Here is my result from Tuesday...
Nothing amazing, as there were a few things holding it back. One of the main things mentioned was that my exhaust (which was very quiet on the dyno) seems to be restricting flow too much. Tuner said the engine seemed to be having trouble breathing. So i'll probably have to look at getting rid of the cat, and/or changing the muffler. (it is 3" all the way through).
Exhaust cam timing wasn't adjusted this time due to the above ^^
This was also only on 18psi.
another t67?
Another T67
Some more info;
T67-25G
RB25 rebuilt with forged pistons, stronger bolts & bearings etc..)
Quickspool exhaust manifold (almost identical to 6boost)
Fake greddy plenum
Link G4 ECU
Big front mount
98 unleaded
18psi boost at the moment as I'm only using the built in 2.5bar link MAP, and a weak spring in the gate.
I will get around to starting a proper build thread for my car, eventually...
That's actually another decent result for the T67, between 4 and 4.5 for peak torque and 180kw so its definitely on the boil at the right time and you can tell power is still rising and could rev harder.
Retard the exhaust cam free up that exhaust, I rekon gain 300 rpm in spool and with a few more psi an easy 320kw.
make it dance!
After what I've read here about his shitty service I won't be contemplating buying his products. And I am in the market for a 250-300kwish bolt on for an RB25.
probably best that you don't buy kando turbo anyway as they are NOT a bolt on for Rb25.
look at the hypergear if you require a bolt on 300rwkw turbo for your 25 with a nice right angle mount straight off the housing for the ext gate (perfect for flow too :P)
i was being serious GtScott, cause if he doesn't get what he expects, you know he's coming right back here.
LOL Oh well. Cant help those who cannot be helped.
FYI to anyone wanting to buy products online or from the US:
I got my cams from Real Street Performance. From payment to delivered was 8 days (1 week and 1 day), inclusive of a weekend.
The cams were also cheaper than ANYWHERE else I had seen (only 380 USD for the pair, 220 USD for the springs and Ti retainers). Shipping was a good 90 bucks, but hell worth it, they came PROPERLY packaged and super fast.
I have bought my injectors, AFM and wastegate from Ebay USA, delivery to door takes roughly two weeks.. This bloody Eiji hasnt responded to my email sent yesterday and one today. Does he want to sell his Kando stuff or not.. :no:
Ebay Jase?
Its the same store as the on ebay, but I emailed them direct and they sent me a simple paypal invoice
http://realstreetperformance.com/store/
They do the PT stuff too, so you can look there for a super quick delivery and decent price 6262 when your time comes ;)
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
