nah was a t28! lol
but thats my point its good to see how it ramps on/power curve with certain peoples setups etc etc etc
My cars torque was OVER NINE THOUSDANDDDDDDDD
Just wanted to belong :wave:
Hypergear has mentioned in the past that testing on port covers proved that the a minor amount of response was lost and it required more boost to make the same power.
Surge point was obviously shifted and his recommendation was to only run a surge housing when required.
Yeah i did mention maybe its just the difference between the two dyno's making them appear to be delivering differing reults.
Im not complaining in anyway, once i can get back to the dyno and put 20psi in it i should reach my goal of 400rwhp.
hmm so meth made 330 ish rwkw on 24 psi with e85 ? i got 311 on 19 with 98 would like to see number with e85 and boostin it up just for coupple power runs see see if i can get close to the number being ran on the hubs
switched over to normal .7 front housing this morning :) completey different 2 drive now, even faster spool, 1.2bar boost ( gate pressure atm ) by 4000rpm in 4th rolling at 80kmph.
330kw on pump 98 is easy done, i use to run 28psi thru a 3582r on bp98 tune before this turbo and made 480rwhp, was a very safe tune.
also realised vct wasnt switched on, got new map sent over email earlier and now vct is on, this thing is responsive :)
Edited by methz
no surge noticed yet, with anti surge housing i noticed it slightly in 3rd at low rpm ramping onto boost.. going 4 a drive tnite 2 see how surge goes, time 2 wind the boost back into it.
new cover + vct setup correctly, its like a dif setup, comes on boost so much better and harder.
Edited by methz
Just a quick question, have been reading this thread but havn't exactly found what im looking for.
Basically, im wanting to buy a TD06 20G for my R33 skyline, im not sure if i should go anti surge front housing or non anti surge? i have heard the anti surge makes less power and not as responsive etc whereas the non anti surge makes more HP and is still a proven performer if tuned right etc?
specs on car if wanted:
Stock RB25 engine
s/s highmount
38mm tial gate, 1 bar spring
740cc injectors
freddy plenum
80mmThrottle body
exhaust
greddy digital boost controller
fmic
looking forward to your replies!!
A Freddy plenum isn't really going to help much either..the stock one can handle anything a td06 20g can throw at it....probably make better torque too..also if you get the right ecu you won't need a boost controller ;)
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
