Id been having trouble holding boost, and bought a new wastegate actuator. When i went to remove the stock one, i found that even with the actuator rod fully in, the wastegate was actually about half a mm open!
Installed the new actuator, putting plenty of pretension on it so the gate was held firmly closed.
Fired it up and went for a spin. Once warm i gave it a 3/4 squeeze in 2nd from about 40km/h, the thing came on boost like never before and snaked beautifully up the road! I then realised that i hadnt changed my EBC settings, still set for the old actuator, and that i had just experienced 1.45bar! oops! but knock levels were well under 20 so i wasnt too worried. I adjusted the EBC and set between 1.2-1.3bar.
The car was now feeling better and crisper than ever, and was holding boost longer, but still falling to just under 1bar at the very top end.
Off to Morpowa for another tidy up tune, i was expecting good results.
This being the third tune so far, produced even LESS peak power, at 218rwkw. What had i done? I'd fitted a hiflow cat since the last tune, and it literally killed top end power. When having the cat fitted i was told id lose a few rwkw at most, but after seeing the power result i rang Exh Tech and was told that with the boost and turbo im running, it would easily cost me 10rwkw or so.
But after driving the car after this final tune, the peak power didnt bother me at all, as the car is by far the quickest its ever been. It now pulls like it did when i ran 1.4bar boost, lighting up second beautifully on a boosting roll on! Put it this way, if i was told that the car made 235rwkw id have believed it. (the original tune made 227 and it feels quicker now)
Just for curiosity's sake, i pulled the new cat for a test on a private road. Immediate obvious seat of pants difference. Spool up is noticably even quicker, especially in 3rd and 4th. It feels very fast but i couldnt rev it out, as i hit 100% inj duty cycle pretty much immediately after boosting!
I already have injectors on the way. Needless to say i will be exploring a "super" hi-flow cat option (some sort of custom arrangement) and when the new injectors go in we'll see how she goes.
As for the boost not holding to get a good peak power, ATS says its because the RB25 at 1.2-1.3bar creates too much exh flow through the turbine, which spins the compressor out of its efficiency range, and instead of pumping/compressing the air, it "chops" it, and causes boost to fall off. This problem is not apparent on an RB20. So i guess it could be said that this turbo is too small for an RB25, which i have argued in the past, but damn the thing is so punchy and torquey through the midrange, that on the street it is more than suitable.
the perfect example is the red 300zx i ran last night, he had 250rwkw vs my 218rwkw. I ate him, shifting at 6000rpm. If thats not a perfect example of how midrange torque and "AVERAGE" power is more important than "PEAK" power, then i dont know what is!
Overall very happy with this turbo, and i'm still confident that with a less restrictive exhaust, i hope to see easily over 230kw at the wheels.
https://www.sau.com.au/forums/topic/34796-gt2530-results-update/
  • Replies 44
knore, when i bought the car it had a gutted cat. I replaced this with a new 3in hiflow cat. It just proved to be more restrictive than i thought. The car has all the usual basic bolt on mods. Exh, CAI and pod, FMIC, fuel pump, FC, clutch, EBC etc etc plus 2 way diff and upgraded brakes.
the turbo setup cost me $1800 + a few braided lines i had to get, so all up under 2grand. (also 170 or so for a tomei fuel pres reg as using std injectors)
Had some runs tonight against a GTR with twin GT2530's (you know who you are!). Off the line of course no chance, rolling run also of course no chance, but i was surprised how well the car hung in there, and i think so was he! Also played with a jap spec STi WRX running 1.8bar and possibly a bigger turbo. Wasnt even going to try off the line, but rolling run, see ya later!
sounds nice Sly, shame the cat is hurting. I saw a comparison in '21st Century Performance' a book by Julain Edgar, and he came to the same conclusion as you - high flow cats dont flow that high.
will be good to see the results with a higher flow cat fitted. What ATS are describing to you is compressor surge, which is a pretty violent sort of thing to happen, and would be accompanied with violent boost fluctuations and a feeling that the car is hesitating/loosing power? is that what you are getting, or am I missing something?
congrats again, the R&D, whilst consuming time and money, can be pretty rewarding - and if nothing else, helps others going down a similar path to you:)
Thats some amazing story about the actuators. I might get a set from HKS just to see. Not expensive anyway. They are all the same right? No specific models to get.
We should go looking for more runs next time :D Take u for a spin next time. :headspin:
Btw, next time ill make sure we match boost for boost. As u know, those GT turbos are only efficient after 1 bar! Youll be suprised what mine does at 1.2bar.
hi steve! yeah shame about the cat, if hiflows are this restrictive id hate to see a normal non-hiflow cat! I dont get compressor surge, which is where the compressor tries to pump more air than the engine can swallow. From what Bill from ATS said its a problem with the comp wheel spinning out of efficiency and losing ability to pump. I dont think the wheel on a 2530 is big enough to cause comp surge.
Im actually surprised at the amount of R&D that im forced to do! I thought that with all the tuning places around doing these cars nowdays that they would pretty much have a full understanding of these little "mystery" problems such as ive had/having, and ended up costing me much more than i budgeted for! But it definitely helps those who want to go the same road!
N/A, yeah i know, they go sick after 1 bar! I can imagine it would be like a jet!
Was $1800 brand new?
Im thinking about going the turbo upgrade for my rb25, either 2530 or 2835
I want something thats a good jump in power, but its not that big i need to upgrade internals or wait till 5000rpm to hit good boost.
Whered you buy it from?
Sly, a "super" high flow is basically a straight thru pipe in a cat housing with no internals - sounds like that's where you started b4 u put on the high flow cat .
If the engine needs to breathe, u will usually see about 10kw difference between a straight thru and a high flow
Don't know much about RB25's, but u could be right that 2530 is too small - hence exhaust flow problems
lets face it, 2x 2530's on RB26 is magic for 300 - 350 kw applications
good luck with the continuing developments - sounds like u need those bigger injectors :-)
i have been tending more towards a 2530 myself now too as i wanna keep motor stock, so i think going fuel pump, injectors and a 2530 would be the go in my case, do you guys think 230rwkw is obtainable with a pwoerfc trust fornt mount full exhaust and EBC is obtainable with a 2530 on a 33 using the standard AFM too ? or would i need a Z32 ?
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
