Hey all,
I purchased my r32 only like a month or 2 ago.
The car feels very slow/sluggish until boost kicks in.
I get munched by little yaris/jazz/swifts etc... at the lights (just driving normally)
Boost on car does not kick in until atleast 4-4.5k!
Car has fair bit of work done to it.
CAI
Pod
FMIC
3" TBE
Pon cams
Cam gears
Bigger injectors
Better coilpacks
Z32 AFM
Upgraded fuel pump
Bigger turbo
Nistune ecu (can't remember if that's the correct name)
Few other bits.
I hardly ever floor/race my car as turbo lags and it drinks so much petrol... i'm a GRANNY driver! LOL.
However when i drive normally it's so slow/sluggish... all these cars just overtake me and the ones driving behind me get's frustrated that i'm so slow.
Car does not feel like a straight 6 down low in the rev unless turbo kicks in. Getting overtaken and beaten by 1.3L is a disgrace!
Is this normal or what's up with the car?
Any advice/help would be great.
Thanks guys.
Edited by starscream_r32
Sounds like you have a bad case of rb20, only way to fix it is with some extra capacity.
Also didnt you test drive this vehicle before driving it? Even if you were just riding passneger it should have been fairly obvious what sought of power you were getting.
Find out exactly the specs of the cams are, as they don't add power, but shift the power up higher in the revs which is why you are seeing no low to mid-end power, great for track driving... not so for daily driving. You could dial in the adj. gears to help bring the turbos on earlier but need a dyno to confirm the changes.
lol.. guys i'm talking about racing off the line!
i'm saying normal driving/take off it's slow/sluggish unless i put the foot down and get it into the turbo boost band.
should still have some umphh even without the turbo kicking in? Its' an inline 6! feels slower then a 4cylinder. loll.
Turbo is hypergear 28?
Yes car is tuned.. (probs needs a retune) but it is tuned with current mods. about 235rwkw on dyno sheets.
its an RB20... has no VCT
There not that punchy off boost, but they do rev nice, most of the power is when the turbo comes in, and without the VCT you dont feel the torque like you do with a RB25
Please show a photo of this turbo or the person whom you've got it from, I will be able to give you some specifications of it if it is one of ours. Also check the wastegate actuator adjustment. Make sure its tightly shut.
A healthy RB20det should still be pretty ok down low even without VCT. I would check cam timing and have a play with cam gear settings.
u sure it doesnt have a dirty big set of 280 cam and some poorly matched or hybrid turbo?
cam and turbo selection can quiet easily make it feel like a bucket of shit down low
type in www.google.com and search RB20 lag...
Do some research on what parts you already have prior to running to a tuner. many will pick up you haven't got a clue and wrought you..
RB20's do not have low down torque. dont expect much until it comes on boost or at least is well above 3krpm.
RB20s are crap off boost. think of it like this, a 2 litre towing a 1300kg car, slow... 235rwkw from a 20 makes me think it would be really laggy which would then make the painful wait for boost even longer! i know mine is painful but my boost starts at just over 2000rpm (stock turbo lol)
having said that i don't know what difference cams and some of the other mods would make, mine only makes just over 160rwkw
haha what you expect? To drive around below 2000rpm? This aint a V8. The engine was designed to rev out. Hell, the redline is 7700rpm afterall. If you are after more response, sell off the turbo and replace with a HKS2530. Comes on boost at 3800rpm~ and will give you max power of 210kw~ Else, live with it and rev out to 4000-5000rpm between shifts.
My r32 has an average fuel economy of 11.5Ltrs/100km~ Work out if yours is similar.
if you take the car on the track, you wont be seeing under 4000rpm anyways, so decide what the plan with the car is and start to change whatever you dont like.
i rarely got past 3k.
so ur saying if i keep all gear changes under 3k without kicking the turbo in then from stat to finish ill always be slower/behind other cars?
even lilttle 1.3,1.5L etcc are faster/ahead of me?
dunnoo. if u guys get what i'm talking about but yer... maybe u needa be in the car to understand..
everyone that sits in my car thinks its slow cos i keep it under 3k and not let the turbo kick in... but boy do they get a surprise when i rev it though..
lollll..
i'll get a retune and fix a few little stuff and see how i go..
turbo cars are designed to go fast when boosted. Simple as that.
non turbo cars have the advantage of no lag, and I think your forgetting that some little cars, even with there small 1.4L engines etc, are still quite light and if there putting there foot flat to the floor, the engine will be at its peak performance, where as your RB20 at say 1/4 throttle, off boost will be no where near its potential.
your saying we arent getting it? is there a better way you can explain it if the above is not how your driving it?
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
