  • Replies 163
currently in negotiation for my discounted tickets .... but should be there .... someone just tell me where and when we meeting .... i want to start off at Berlin .... and be back in time for Hybrid at metros.
https://www.sau.com.au/forums/topic/34799-two-tribes/page/4/#findComment-699267
hehe there is a balcony above the vip room dude, its like the chill out area 4 every1
i recon bout 12 cos thats easy to remember, cos my brain mite not be werkin lol
stove
hehehehe very good point there about brains not functioning properly, make it an easy spot to get to with not much thought involved, lol :rofl: :jump: :hippy:
https://www.sau.com.au/forums/topic/34799-two-tribes/page/4/#findComment-699416
OK MEET UP WHEREEVER AND WHENEVER HYBRID IS PLAYING!!!!
Ok Little Fraser, Big Fraser and Rob... Ummm are we talking about Rob, Umm bout 5'10 bit overweight um brown black hair used to drive celica few years ago and has business in Northbridge regularly..... might be a long shot but we all might have seen each other out and not noticd it!!!
nah, rob has an american eagle with a stock (last time I saw it - which was about 10 days ago?) r33.
https://www.sau.com.au/forums/topic/34799-two-tribes/page/4/#findComment-699662
How many old skool ravers are there on this forum?  I thought I was the only one.  Anyone remember prodigy at obsession rave.  God I'm getting old.
yeah im one gtracer, i was at that one and heaps before that, including eclipse, i remember my first was at the freo passenger terminal back in 1992/3? Carl Cox headlined.
https://www.sau.com.au/forums/topic/34799-two-tribes/page/4/#findComment-700232
hahahahaha i could take you up on that, mite need something to chew on :( ive found 5 glow sticks!!!!! i knew i had em somewhere, and ill make sure i bring the whistle just for you Rb_20, so ill be the one with 5 glows sticks hangin off me and a whistle, but ill be "in-tune" with the music
https://www.sau.com.au/forums/topic/34799-two-tribes/page/4/#findComment-701032
