hai guise, its official, im sick of my old tien stiff coils and im getting some new ones, i like stiff suspension, just not as stiff as tiens, slightly softer would be ideal, i have been considoring the BC racing sets on justjap, what are peoples recommendations?
the car is a dailey, but i like the suspension hard, just not as hard as tiens, the car dosent see trackwork.
r33gtst
cheers
https://www.sau.com.au/forums/topic/348051-recomended-choice-for-coilovers/
why not just go for a decent shock revalved to suit a decent spring, rather than go for the you beaut cheapo coilovers that have a million and one adjustability settings which no one except a proper suspension workshop with corner weighting facilities and good experience can get right...
i must ask what advantages do you actually find on a dedicated street driven, is the only reason you have them because you like a hard ride? or is it just so you can change the height? im know heaps of cars out there are daily cars with coilovers but i cant justify spending 2k (for GOOD) adjustables when the way you drive on the street will never require them. i have put the money i could have spent of adjustable coilovers into sway bars, strut bars, heaps of new bushes, giving me some mean camber and caster and rigidity. i would do the same again.
how ever each to their own
Edited by PaulosECR33
I have BC V1's that just went on my car, After a bit of adjustment and playing around Im happy with the height etc atm
There pretty good on the street, I wanted to keep the car relatively driveable so went with the V1's with 8kg front and 6kg rear spring rates
Ive only just got the car going again tonight but the limited driving ive done I like them, there not soft by any means but there much nicer then other skylines I've been in with coilovers, Depends what your after really
as I said there not soft.... but there not that hard either
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
