First thing I learnt in intro to law... you enter into a sale contract and thats it. He would have been pissed if you backed out. If he accepted payment thats accepting the sale contract. He can't just back out like that, but you're hardly going to take him to court over $150 worth of calipers...
I didn't win those other calipers either, so I'm keen on your mates calipers Big Fella!
How much are the seal kits? I saw a set of all four on eBay for about $200, which seemed insane to me just for the seals.
Hoping I might be able to pick them up from Big Fella, or a skyline owner on here upgradng (and maybe even get some second hand discs).
Get your money back for the others?
yeh there about $100 for fronts
rear calipers dont fit on our car so try asking if you can split em up..
yeh got money back.. should be picking the other ones up tomorrow or monday..
craig will.
give craig anything unbreakable and guess what? he'll break it
lol...yup!!!
you guy's looked around for R33GTR stuff yet?...might find them cheaper than Z33/V35 stuff!....front's only!
Just quietly Cam....big f#$king difference between a 20year old cross drilled rotor and a late model Porshe rotors and ceramic Ferrari stuff mate! Every time I have had crossdrilled rotor's on a car(any car) they have eventually cracked!
Edited by Jetwreck
You talking calipers? I've found R32 GTR calipers are cheaper than R33 GTSt. I didn't know R33 GTR fit?
The cost of a rebuilt set of R32 GTR calipers, decent slotted discs and decent pads had me looking at v35/350z stuff, but thats just dearer again!
Yeh callipers and rotors from a R33GTR.......they are basically the same calliper as the Z33/V35 brembo just black.....rotor is 324mm instead of 284 like the r32......will bolt up the same way as the R32's as well.....I know this as I started with the R32gtr calliper and rotors and just recently went to the R33GTR stuff.
Well u coulda told me that before I picked up my gtr32 calipers today.
Meh I don't think it matters, the way scotts was stopping was f**kin insane! I don't think I'll need more than that.. I'm not looking at track work anyway..
The ones I picked up look good.. The seals look new still!
So I'll need a caliper adaptor then?
The washer? Yeah I read Craigs instructions in M35Stagea.info, but he said R33 rotors were 324mm, and R32 rotors were 284, so I'd need that caliper bracket I think? This is the first I'd heard of R33 GTR calipers fitting?
Do they fit over standard wheels? I've still got standard 17" RS wheels.
Oh screw that I'm not going through that much trouble for a couple of mm. If that much trouble is needed, but he said they are the same as 350z brembos so maybe no adaptors.. Just the sleeve washer thing
Craigs Brain and possiblily other parts of him are on holiday ATM.
R32 GTR dicss are 296mmx32mm with Sumitomo calipers (same diameter as stock, the difference is in the width) Not 284mm
The R33 GTR are 324mmx30mm- With the Brembo calipers.
What you need to make them fit- the difference is in the bolts - R32 /33 being 12mm, and R34/M35/Z33 being 14mm (I think :blush:)
A little Sleeve that goes on the bolt to fill that gap is whats needed.
Scott might just jump in here (he turned mine up):thumbsup:
Edited by PN-Mad
R32 GTR, non brembo is 296mm x 32mm. R32 GTSt is 280mm x 28mm. The reducing sleeve for the mounting bolts is all you'll need.
Edit; Alex beat me to it.
Edited by Daleo
Scott might just in here (he turned mine up):thumbsup:
But wouldn't I need an adaptor to move the caliper to accept the bigger R33 GTR disc?
Does that make R34s bolt on too?
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
