Aaron, don't quote your exhaust as a "JASMA cat back system" as those who don't know it is a Kakimoto R may try searching for a "Jazma" brand exhaust.
If a cat-back has JASMA accreditation in Japan, it just means that when held at 3000rpm, the exhaust sound is under 95dB.
Yeah, it is about the same volume as a Fujitsubo Legalis (~90dB) and a touch louder than my Nismo
If you really want quiet, you just cannot beat a Blitz NUR for NM35's.
sorry sir. please dont beat me with your bohemath like hands :ph34r:
I find it makes a fair difference on mine, dare I ask are you sure you opened it up the whole way? bigkevracer was in my car for half the SA Stagea cruise on the weekend and thought the exhaust sounded like it almost had a slight leak at 2-2.5k RPM when on the highway cruising..I dropped it into silent and I think the reaction was basically a 'Well, yep. That switch is definitely working, and you definitely dont have a leak'. Stealth mode ftw :ninja:
sorry mate i should mention i only have the rear muffler on the car. the mid one is still the big stock one. hence why it didnt make a HUGE difference. however it has a nice note to it! and a nice rumble at idle :)
stephen was running his the entire time with the valve closed, i never heard it with the valve open!
pipster, keeping the car quiet is exactly what i want it for. i dont give a crap about performance. thats what opening it again does :)
I can vouch for that. Totally astounded that an exhaust I could see through was as quiet as stock. It is louder at the back when you get up it, which is nice, & deeper at idle, which is also nice :), but mainly I noticed that the induction noise dropped way down (not sure of science behind this) so overall NVA is reduced when driving normally. There's no doubt that Japanese exhaust designers/manufacturers know their craft.
I have before & after videos which I will post on the exhasut thread soon for those interested.
yes please Leon!!
also mention if you have a dump/front pipe too with the videos
yeh i noticed my exhaust became a little louder and "tinny"(if that describes it) when i put on scotts Dump.
i'de like to see a video tooo leon!
Yep, will get onto it. Might get my daughter to compile & subtitle them since that's not really my thing. I should actually do one more so that I have:
a) totally stock - with the centre muffler that's the size of Iain's villa, lol
b) with Scotty's dump pipe and Blitz cat back, but still with 2.5" front pipe & cat
c) as it is now with 3" front pipe & hi-flow cat installed (I need to video this one still).
I even got the measuring tape out so that each video was recorded at 50cm from tip. Otherwise it's impossible to compare sound levels from one to the others. Mmm, reading this back makes me seem a bit OCD or autistic :rolleyes:.
Edited by Commsman
i might follow in your OCD Path and do it at 50CM away lol
Yeah buddy, do that. I'd love to hear the difference. Hold it just off to the passenger side. My son held it almost straight on the first time & the lens fogged up with the moisture pinch.gif.
Although, different cameras will have different microphones so it won't be a really accurate comparison.
Edited by Commsman
my villa is pretty big dude, and i have double garage. so i dont know how big your muffler is :P
No offence :unsure: . I am just remembering you saying recently that the centre muffler on your car (same as mine) was "as big as your house". Now that today we have established you live in a villa, I just thought I'd be more accurate. Again, part of my autism, lol
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
