Driving to work this morning, the heater isn't working. Just blowing cold air all morning. Temps were normal, didn't think too much about it. Just turned the climate control on and off a few times, didn't seem to do anything.
Then closer to work, temp is creeping up. Higher than normal but nothing ridiculous. Of course before long it's just below the H, I pull over and it's steaming.
Thing is, I reckon it's been cracked for a while. When I picked it up from the Toll depot there was a bit of coolant around the place, but the car never seemed to be complaining so I figured it was a previous coolant splash that had never been washed off. If this wasn't the case, then I've most likely been driving it around like normal, leaking the coolant slowly (the TransportSA inspection guys didn't say anything either), to the point where it's empty.
So yeah that's how my hour and a half commute to work was today. How hard is it to find radiators for these things?
Sorry to hear that. Seems like the previous owner hid the issue pretty well...or did the issue not manifest it self till now?
That was a m35 one yeah? Anyone know if v35 and m35 are identical?
Brad, ducati02 on here, did his radiator late last year - brief summary of it http://www.m35stagea.info/forum/viewtopic.php?f=2&t=114&p=1048
Are you sure the radiator is cracked? The water only has to be half a litre short to show these kind of overheating issues, even 200ml will cause problems.
Can't say I'm 100% sure. Any way to test without one of those pressure things?
Just so you know the V35 manual one fit's in with a little bit of cutting......I had one in mine....I lent it to someone about 6 months ago for a couple of weeks. :P
When I do get it back it will be for sale.
Usually the Oring goes on the top tank. It may hold pressure fine until its hot. These can be replaced.
I would just fill the system from the rear bleeder, behind the drivers side head, and check it a few times to make sure its full. If it still leaks there is a problem.
The coolant can spurt out the top of the overflow container if it gets full which could be your spray in the engine bay.
They also had to fit a radiator to mine prior to compliance as it had a split tank, so it must be common?
You reckon fill it up and give it a few more days to see how it goes?
Where is this Oring? I need to get FAST sorted out so I can look at the diagrams...
Yep, I have had the overheating thing so many times, I just fill at the rear bleed and it goes away. That said, if it is leaking you should keep a few litres of water in the back just in case.
If the top tank is cracked you will definitely know about it. The Oring seals the whole underside of the top tank and usually only weeps when warm, sometimes it sprays out from one side.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
