Driving to work this morning, the heater isn't working. Just blowing cold air all morning. Temps were normal, didn't think too much about it. Just turned the climate control on and off a few times, didn't seem to do anything.
Then closer to work, temp is creeping up. Higher than normal but nothing ridiculous. Of course before long it's just below the H, I pull over and it's steaming.
Thing is, I reckon it's been cracked for a while. When I picked it up from the Toll depot there was a bit of coolant around the place, but the car never seemed to be complaining so I figured it was a previous coolant splash that had never been washed off. If this wasn't the case, then I've most likely been driving it around like normal, leaking the coolant slowly (the TransportSA inspection guys didn't say anything either), to the point where it's empty.
So yeah that's how my hour and a half commute to work was today. How hard is it to find radiators for these things?
Sorry to hear that. Seems like the previous owner hid the issue pretty well...or did the issue not manifest it self till now?
That was a m35 one yeah? Anyone know if v35 and m35 are identical?
Brad, ducati02 on here, did his radiator late last year - brief summary of it http://www.m35stagea.info/forum/viewtopic.php?f=2&t=114&p=1048
Are you sure the radiator is cracked? The water only has to be half a litre short to show these kind of overheating issues, even 200ml will cause problems.
Can't say I'm 100% sure. Any way to test without one of those pressure things?
Just so you know the V35 manual one fit's in with a little bit of cutting......I had one in mine....I lent it to someone about 6 months ago for a couple of weeks. :P
When I do get it back it will be for sale.
Usually the Oring goes on the top tank. It may hold pressure fine until its hot. These can be replaced.
I would just fill the system from the rear bleeder, behind the drivers side head, and check it a few times to make sure its full. If it still leaks there is a problem.
The coolant can spurt out the top of the overflow container if it gets full which could be your spray in the engine bay.
They also had to fit a radiator to mine prior to compliance as it had a split tank, so it must be common?
You reckon fill it up and give it a few more days to see how it goes?
Where is this Oring? I need to get FAST sorted out so I can look at the diagrams...
Yep, I have had the overheating thing so many times, I just fill at the rear bleed and it goes away. That said, if it is leaking you should keep a few litres of water in the back just in case.
If the top tank is cracked you will definitely know about it. The Oring seals the whole underside of the top tank and usually only weeps when warm, sometimes it sprays out from one side.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
