Just picked up a cargo net from slippylotion.
Really thrilled to go to fit it and find that Northshore have put the child anchor points in line with the rear cargo net mount :domokun:
Dunno whether to call Ben and tell him (at least they won't do it to anyone elses), remove them or just not worry about it.
Look nice Jase and I see you went with KU31's.
What size rims did you get?
Yeah ended up going with them in the end after you were talking about the wheel bearing. From all accounts they seem to be a good value to performance trade off. If they are noisy I'll just have to deal with it.
Ended up going for 19x9.5+20 after speaking with Chris (spoolin12). Seems like pretty safe fitment - any further and it's hassles.
Ryan, those mounts should be in the same position as mine, they should all be fitted in regs with the evidence pack from RAWS.
I'll check it again in the light of day, because the pole didn't seem to be telescoping right either.
That's the idea to be honest. I love Japanese cars but our good friends in the police force don't, so I'm trying to make this car look as tough as I can without attention from the boys in blue. Euro all the way. :thumbsup:
I like em... Varrstoen make a wheel like those.
What make are they?
What tyre size did you go with?
Edited by impul535w
What make are they?
Avants. Tricky to get though.. I saw the Varrstoens but they weren't concave enough for my liking. Or the other ones had the dish which wasn't for me.
There are a few others. Monotec I think they are called. And then Aluflugens I think.
As per spoolin's recommendation, 245/40's. I think from memory 265/35 would have been ideal rolling diameter but maybe lacked the minimal amount of stretch that mine have (really it is barely noticeable, you have to look hard to see it)
Got a spare key coded this morning. Mine is keyless entry/start - so cannot be programmed with the lock door procedure. Hornsby Nissan did it - $178.60 for the remote (without emergency key, as its not needed) and $134 for the code (about 1hr labour charge I think)
So, spare key - $312.60, pretty good I think.
top work on the spare key. on a side note PN-Mad is looking for a donar kidney as his last one just went to nissan.
Edited by joshm35
Lol... yeah- thats going to be cheap compared to what I'm going to fork out over the next few months!
Need a spare key really- I have heard some horror stories about the cost of keys, up to $800! Its blatant rip offs I think. Plus, tow truck from teh edge of bum f nowhere would be far more painful!
If only it was as simple as the door lock coding thing! Trust me, I tried it, before I contacted Chris Rodgers. Your pretty much stuffed if you don't have the Nissan system.
After seeing slippy's wheels tonight I think I'm going to go that way... 18x9 +30s, right?
Perfect stance to me with those 45 profile tyres! :thumbsup:
Yep, thats the sizes. Im happy with them and the look.
How did you go with the cargo net fitting?
Hey Paul,
Has the cargo barrier already been sold? I spoke to vince today and all good.
Or you have two?
If not big kev, send me some pics after your install if pos. Love to work out how to install it....
All good there is two for sale. Bigkevracer bought one and you for the second one.
Send me your number and I'll send you pics of it installed.
Edited by slippylotion
http://www.skylinesaustralia.com/forums/topic/376446-sa-s1-c34-cargo-net-frontrear-swaybars/page__gopid__6040082#entry6040082
I need to sell my C34 cargo barrier net. Never used it in 75-odd months Ive owned the Stagea.
Nothing new with my stagea - have no idea when the bottom end will be ready & engine reinstalled. :(
Been studying some text books ready for Med.Science next year at Uni; mind is currently full of bodypart names (anatomy)
Hitting up the Beta for Battlefield 3 for study breaks..... awesome game.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
