  • Replies 53
Wow..thats actually alot more affordable than i had imagined..
Well worth considering
What would a quick rebuild on a 25 block set you back, im thinking 1500-2000 with rebore, quality bolts, bearings and pistons.
Only thing Im worried about is your turbo not liking the extra capacity cause then your going to be forking out for new turbo as well, then you would probably need new injectors .....................
And so on the snowball begins.
Edited by Arthur T3
Maybe,
Does your turbo drop off now or would it handle a 8-8500rpm redline?
Cause i get the feeling that some more revs and some extra comp (say 9.5) would make it deadly fast and responsive. But im only guessing.
Are you talking about if he stayed RB25?
His turbo would not handle 8,500rpm redline on an RB30. I think joey would be happy if it handled 7000rpm well on the RB30. That was my point that 9.5 comp would be super nice on the RB30 but I think the RIPS standard refreshed engine is a great deal.
Yeah was talking about a built 25..
RIPS is a good deal but is it compatible with his current setup is the big Q. I mean its no good getting it to find out its not, then you have to spend as much again to set it up properly.
But a decent bottom end that can handle 8000rpm , decent pistons alone could provide some extra torque, It may not make much more power but it will make it quicker and stronger for longer..
Plus buying an engine form NZ means alot of hassles if it plays up, not like u can drive in and complain, and there is plenty of good engine builders nearby his area
Im not knocking the 25/30 at all just adding another point of view.
Edited by Arthur T3
yeah i'm just trying to research it all atm... that turbo was still climbing when it was shut off at 7400 but not very steeply
i'm thinking that it's really not that much smaller than the 3076 .82, so it should manage a redline of 7000 or just shy of...
The HKS 2835 Pro S seems to have just as much top end as a 3071 0.82 on an RB25. And there are plenty of results similar to the 3076 0.82.
Even if it does nose over just before 7000rpm that would still be a very nice setup. The other thing I was thinking of is that the HKS 2835 Pro S came in a 0.87 exhaust housing although I am not sure if it is T3 as well. A 0.87 exhaust housing would be ideal imo
yeh... i'm thinking this should be a goer :)
worst case scenario will be a new rear i spose, but if it makes 6500, i'll just set the redline to 6,800 and be done with it ;)
Even if power drops off, as long its more power than the next gear up at that speed you are still better off revving it out to 7,000rpm or whatever the engine is safe to. Same as how a standard turbo power drops off over 5,500-6,000rpm but you are still better revving it out to rev limiter.
Check out this link:
http://www.allpar.com/eek/hp-vs-torque.html
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
