hi guys,
my new r32gtr has a thin film of black soot which does come off with polish but it is very stubborn...is there a chemical i can get to remove this stuff?
here is a pic to give u an idea of the buildup, mainly around the top of the firewall (above the engine)
regards
marko
Edited by Marko R1
https://www.sau.com.au/forums/topic/349155-best-way-to-clean-an-engine-bay/
Try spraying with trigger bottle - truck wash detergent 50/50 with water , scrub with wheel/rim brush let soak for 1 hour then gentle wash of areas affected only ,
whatever you do try not to wet your intake filters or any electrics .thumbsup.gif
what works best for me is a can of crc heavy duty parts and throttle body cleaner. The dirt literally just glides straight off!
^ ^ ^ Yes, preceded by Kenco Truck degreaser &/or followed by Upper Engine Cleaner by Subaru...
But...
But...
Your car is red, and some reds can change colour slightly by using harsh solvents.
So I'd tend to do a test-wipe first eh?
ok - i know that throttle body cleaner is incredibly strong when it took all the grime off my throttle bodies when i had them out, makes your fingers feel tingly as well which cant be good lol
i'll try this & that kenco degreaser
I would be very interested to know how u end up Marko.
I have the same problem with my gtr, I attempted using a small spot of WD40 then rincing with soapy water and rubbing over with a polish (washed the wd40 off quite quickly).
Appeared to work quite well, however i can see this being quite time consuming. Besides its quite difficult to get a cloth to some of the panels that are quite dirty in mine.
Also dont like the idea of spraying WD40 all over my paintwork.
Kenco Degreaser is fantastic, I used it for my engine bay a few months ago. Spray on leave for 15 mins and give it a bit of a scrub with a wheel brush. Pretty much everything came off. More stubborn spots got more degreaser and a longer soak time. :thumbsup:
Hey mate,
I just used a degreaser and a high pressure spray (u can go to the pay and spray at a petrol station if u dont have a high pressure unit)
Simple Green is highly recommended by the guys at final inspection, but I've never tried it before, I just used up some cheaper stuff myself really
Jif can scrape away grime > but it leaves scratches. If you rub it on a piece of glass mirror you'll see it straight away due to its abrasives.
Kenco Truck Degreaser won't scratch.
Carbie cleaner or Upper engine cleaner doesn't have abrasives either, but it strips away any 'Clear'.
I have no doubt that Jif will help restore any discoloured white, red or any other colour engine bay.
After all, even Glym Paint Restorer will have 'cutting compound' in it.
Any abrasive cutting compound on paint needs to be followed up by a very fine polish, and that can be followed up by wax, and then by a sealer.
Repeated use of cutting compound on paint and...
In your case, it was wise to apply polish straight after, Brad.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
