The bolt was a cam cover baffle bolt head that broke off. Unfortunate but not really relevent to this.
interesting.. when we pulled my motor down for a freshen up, we found all 6 cam cover baffle bolts from one side in the sump. Amazingly they seem to have done no serious damage to anything (some marks on one of the cam shafts, but engineers have pronounced it fine.
Wonder how commonly this happens.
Sounds like very poor workmanship! Who screwed the motor together?
i can see how it would get into the sump (via. external oil feed or even down an oil return if theyre drilled out) but for it to get into the pick-up then the oil pump is very interesting. any theories Duncan?
Has the gauze screen on the oil pickup tube been removed? I can't see any other way that a piece that big could work its way into an oil pump.
I am surprised that a bolt was actually able to make it to the oil pump.
yes i was wondering when i first read the thread how the bolt head made it to the oil pump. i also came to the conclusion that the filter gauze on the pick up must of been removed lol. ?? i know its unrelated to nitto's great servive but tell us duncan how did it make it that far through the oil system :S
Yes that is very straightforward. I run a much larger custom sump with an external oil pickup (it taps into the side of the nitto pump). When originally assembled the sump builder provided an inline mesh filter. The workshop that built the motor removed that mesh filter and ran a straight pipe. I have no idea why. Yes it was a bad decision. No I am not going to name the workshop.
So basically you got some favours the common man wouldn't... Cool story Uncle Dunc :P
Totally incorrect. I have never spoken to a person from Nitto prior to last week. My only dealing with them was to buy a single oil pump at retail. I am not saying they would do this all the time, or for everyone, but I think it was amazing service to do so for *anyone*
Very easy to overtighten those bolts and turn the head off.
What he said. They are M4 bolts, I can't find them in the factory workshop manual so I use the general guide of 6nm (ie f**k all). I will always replace them all every motor from now on as I do with many other engine bolts, too easy to torque them incorrectly.
BTW, its sad how the internet seems to be full of people who want to put shit on every business. sometimes companies do the right thing, and I think it should be recognised among all the bad stories out there.
was nothing like that. Motor lasted 2.5 years making 600hp, ~15 track days, 2 drag days, over 200 dyno runs and ~15000 street km's.
We're taking measures to make sure it doesn't happen again. Best we can figure, combination of heat and vibration has caused them to come loose.
Wont be heat or vibration that has caused your problem mate. As these are never a problem on a standard engine and there are many that have done 100000 + klm's without this issue. Bearing in mind that cam cover baffles are not a part that actually see's any load at all so the extra power output has nothing to do with it. It will simply be a case of the bolts being reused and overtorqued. You are extremely luck that no major damage was done. Best bet would be to replace with new bolts off the top of my head i think the torque seeting if 4-5ft/lb but i would double check.
The level of support is extraordinary; +++ to the Nitto boys.
my thoughts too.
Never seen it.
Good to see Nitto getting some support on here. To be honest when my engine builder suggested to use Nitto id never even heard of them so i did some research and found a lot of negativity on here. I trusted Paul's (Red R Racing) experience and judgement on this and upon reading this thread im glad i did. Excellent work Nitto especially Andrew, well done.
As Red R doesnt use any rear breather on the head they always recommend Mines style rocker cover baffles, when they are fitted a small dob of ultra grey is applied on the bolt head and smeared across to the inside radius inside ensuring bolt security. All these little tricks are what separates the good builders from the not so good.
Andrew was always a str8 up guy even when he was @ turbosmart.
in standard form they're nuts not bolts but nissan manual says 9-12NM which is the same as the cam cap bolts
In standard for they are m4 bolts. There is no stud to put a nut onto (Have built quite a few RB's so have a bit of an idea of whats in them).
thats a dam good idea.... and your so right, its all the little things like that ^^ that really make it all worth it!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
