Everytime I start my V36 it pops up with a warning message in Japanese.
A friend who can read some tells me it's something about Engine Oil, presumably 'please change it'.
My car came into the country with 10,000kms on the clock and I assume a full oil change was done during compliance. It's done 16,000kms now.
I also know in the menus there is a setting where you can adjust the service intervals and all that.
Does anyone know if this warning appears due to sensors in the car, i.e. it can tell the oil needs changing, or is it something that service guys manually reset during a service (which they neglected to do, fair enough being all in Jap).
https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/
I hope your compliance workshop actually changed the oil.... Im pretty sure that the one who did my car didint drop the oil
Yep I had doubts on whether the compliance shop did change the oil in my V36 as well, so I just changed it since I've done just under 5,000km in it myself in the last 4 months. Figured I'd rather be safe than sorry, got some Mobil 1 5W-30 and changed it myself, along with a new K&N HP-1008 oil filter, all up around $120. At least now I have peace-of-mind.
Would you trust the compliance shop? Do you know them personally? My advice would be to just change it if you're unsure, or just get your mechanic to do it. I would say most compliance shops are genuine and would have done their job properly, but why take the risk? For the sake of $120, I'd rather just change it and not find out the hard way they didn't change it!
  • 1 year later...
  • 1 year later...
Did you guys read the thread....?
it's manually set. you can set it yourself inside one of the menu options. check loz's jap translation sticky
If its like the v35 then it has engine oil, engine oil filter, air filter, and something else I can't remember. It is manually set for xkms.
Using CamDictionary for Android, that error message posted above says "Oil filter - set distance has been reached, press maintanance button"
f**king technology, insane!
My second error reads "Engine oil - set distance has been reached. Press the switch information, maintanance. You can set information you chose"
Guess I'm due for a service!
Edited by awsam
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
