They should juuuust fit, but you'll need to use 15mm or 20mm spacers (from memory)
I have a template for this brake kit that you can print, cut out and put inside your current wheel to see if they will fit... but it is on the home PC. Will post it up tonight.
Here is the direct link to the brake template: Liiiiiiiinnnnk
Yep, that's the one. Thanks!
(no need to turn on the PC tonight then :thumbsup: )
Awesome upgrade Chris, have wanted to do this for just over a year now... just need to get the wheels to fit them first lol
Interested to know though, is there is any brake dust or squealing from the pads?
I ordered them and though 'shit, these better fit' :whistling: Lucky it worked out!
No squeeking, or dust (yet). I put some new pads in my standard brakes a few months back and they constantly made noise. Drove me nuts.
So today I drove into the city and am blown away by the power and feel of them. So i am pretty stoked with the upgrade.
do you there there is more pedal travel due to the small master cylinder?
it might require an upgrade
It makes no difference to the master cylinder - I reckon they feel a lot stiffer under foot, I know my brembos felt so much firmer under foot than the stockies, same with Chris'.
  • 3 weeks later...
Hey Chris,
completely OT, but how do you find the FK452's on the Stagea ?
I had a set on my last RWD and they were fantastic, have been thinking about getting a set for the Stag.
Looking at the I.D. of your wheels Chris, I'm sure they would fit behind the 350GT 18's I bought from you. Maybe measure when you do the 1000km bolt check and I'll measure the 18's?
The only thing I'd have doubts about is the caliper to wheel claerance, the calipers look very wide!
BTW nice pics in the current AMB mag, best job ever?:worship:
Hello, I checked with a supplier of these brakes on the G35driver.com forums. The 18" V35 coupe wheels require a spacer, while the 18" 350Z wheels are a-ok. Unfortunately for me I just bought some 18" coupe wheels, so for my V35 Sedan I might have to look at the Brembo's since my wife drives the car 90% of the time. Anything has got to be better than the single caliper job they used on these things!
Chris is your stagea a 4wd model ? as im looking every where for a brake upgrade kit for my m35 250trs four
trying to fing a 4wd kit
Any 350z or G35 brake kit will fit.
Only difference might be the fluid lines
i have been reading on the brembo and willwood sites and they all say that the 350 z upgrade kits cannot be used on AWD vehicles only rear whell drive
the 250t rs four stageas are AWD ??
seeing as it has 'FOUR' in the name, im gonna say yes lol
all turbo models in australia are AWD. the newer 3.5L models can come in RWD, however they are still automatic
so im being told from u guys that any 350z brake kit will work ???
yet they are telling me you cant use the brake kits on a AWD car ???
your telling me all turbo stags are AWD which i know
AWD and 4WD are different they use different diffs , just to let u know
Maybe PM, bbenny (he has Z33 Brembo's on his NM35) or spoolin12 (as you can see at the start of this thread, he has the 370z Akebono's on his which are much, much larger than the 350z Brembo's).
I believe that [[Danny]] also put 350z Brembo's on his M35 (ARX)
Remember, the 350z (RWD, man or auto) and the V35 (RWD or AWD, man or auto) have the same brake kit from factory as our M35's (RWD or AWD).
Of course I am referring to the non-Brembo cars, but it is a direct replacement if you want to upgrade.
How does a different diff affect the brakes you put on?
Have you asked them WHY they say you can't do it?
If it is a US supplier, ask them if the brake kit will fit a G35x (AWD Infinity G35)
AWD and 4WD are the same model in an M35. the driveline is the same
the NA models (series 1) have 4 speed autos and different diff ratios to suite the 4 speed.
the ONLY difference in driveline is the models with HICAS have a different rear subframe, ARX and AXIS has a slightly wider wheelbase, probably in the knuckle as the arms appear to be the same length
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
