Hi all.
Jan General Meeting is going to be run as a cruise as there is not a lot to talk about specifically at this time.
So give your ride a wash and a polish and lets go for a nice summer evening drive and take a few pictures of the cars and so on.
When: Tues 18th, Jan
Meet Point: Aughtie Drive - Albert Park.
In the Car Park near the Sth Melb soccer club
Time: Meet 7:30, Depart 8:00pm
Where are we going? Tis a secret!!!
Other Information: Ensure you have a full tank of fuel. This isn’t a super long cruise. However it’s never cool to run out of fuel :)
See you all then.
  • Replies 55
And yes, this is the same as general meetings - open event.
However for Membership applications, its preferred you use EFT rather than cash, and use the online webform.
It's much much easier for us to administer that way.
There is nothing wrong with NAB EFT. It's not risker today, than any other bank
Ok cool thanks man!
Charles, normal people eat before 8pm!
I suggest you feed yourself before coming along ;)
lol
by looks of things my planed qld trip for next week may not happen so might pop by if i get my intercooler and new front bar on by then
I'd love to come to this or any general meet for that matter but I work every Tuesday night! Seems any major SAU event (like DECA) is on my weekend on too. I think one of the organisers must work opposite weekends to me.pinch.gif
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
