Diagoins Of A Fauly Coil Pack
Guest trikdoutvl
Ok so motorvation is 2 days away and my car decides to sound like a wrx again. exact same thing that happened last year. It was a coil pack. So my question is how do you diagions a fkd a coil pack???? The best way I can describe it is the motor sounds like a wrx and it has fk all power.
https://www.sau.com.au/forums/topic/350032-diagoins-of-a-fauly-coil-pack/
sounds like a wrx and no power... you sure you did not get in a wrx :P
you can visually inspect by running your finger nail around it and see if there is any hair line fracture...
you can do the old turn the car over with the coil pack out and see if any spark excapes...
also think you can check the resistance and make sure all are even...
only other way is to start the car with one off at a time and see which one made no difference (ie you will be running on 5 cylinders with one buggered and as you remove working ones you should go to 4 running cylinders)..
resistance and visual damage does not always mean much , i have seen many that look in perfect condition , measure fine and still die under load
also they often spark at idle but break down under full load
best way to tell is to get a good coil and swap them out one by one and test under load
did you replace all the coil packs with something decent like splitfires last time or did you just replace the 1 with a stock one ?
if so get some splitfires and never worry about it again
if the problem is present on idle just unplug the coilpacks 1 by 1, whichever is the one that doesnt make a difference to how it runs is obviously the dud one.
swap that over to another cylinder and see if the problem has carried over to that cylinder. if it does then that means the coilpack is screwed.
if the problem is still in that cylinder, that means your problem is elsewhere
  • Like 1
Should be careful when checking coilpacks. the way Snozzle mentioned, may blow the coilpack driver (the box that sits at the end of the head).
If you can get to the injectors, diconnect them one at a time to see which cylinder it is. Much safer option unless you know how to check the coilpacks properly.
I would recommend splitfires, never failed on me once with 1.1 gapping and lots of boost.
also don't jump to the coilpacks answer whenever you have a missfiring problem... there are many other possible causes as anything to do with fuel / timing / spark can cause symptoms similar to coilpacks..
personally i've had 3 different occasions when my car was missing... each time the problem was not the coilpacks, despite everyone on the forums suggesting they were.
(mine turned out to be the CAS, then the AFM and then a sticky valve... each were 6 months to a year apart)
also u didnt happen to wash ur engine bay recently? water in the spark plug wells.... coincidently it took 2 days after i washed my engine before misfiring occured and only to find out it was water after a new set of coils had arrive ...Doh!
  • 7 months later...
  • 7 years later...
I started my car last night to visually check my coil packs due to a surging issue, im glade i did, even at idle i could see the spark jumping out onto the motor, so she is gunna sit until I get my new ones, my general rule of thumb is if 1 is on the way out replace the lot, for example if a shockie needs replacement i do all 4 at once
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
