WTF? I'll email him to see how he sent them out. Maybe he used seperate boxes for everything due to weight.
Any one else get their brake kit parts?
Nice! Did you just get the calipers?
So we have one rotor and two calipers between two people, AWESOME! One more person and we will have a full kit :P
Brake lines?! WTF. I told him we didn't need brake lines because we got the Hel ones.
EDIT: Just found two postage pick up slips in the mail box! So maybe my brakes arrived today aswell. I wonder what parts I got lol.
Hahaha ok.
Was hoping you got more today.
Actually the more I think about it, perhaps mine isn't the Wilwood brakes but the V Spec II pedals because it doesn't make sense that I would get mine at the same time as you guys when yours got sent prior to my kit even being ready (remember one kit was on back order)....
Hmmm the plot thickens...
Ohk so apparently I did receive mine today but the old girl forgot to bring them home from work so I'll let you's know tomorrow which parts I received :)
Well it wasn't the pedals like I thought (honestly was hoping it was them just to have that nightmare over) but it was the Wilwoods. Not sure what the go was there considering my kit was ment to be on back order yet I got it at the same time as you guys?
Now it wasn't the whole kit however I think they are sending them in seperate packages like this for two reasons, due to the weight of the kits and also to seperate the order due to customs. I thought they would just dodgy up the invoices a lot more but instead this is probably the better way for every one.
One box contained just the brake rotor and the hat. The hat is extremely light, lighter than I actually thought it would be. I will weigh all the components of the Wilwood kit and factory setup to compare weights when I go to install them. The rotor itself is very chunky!
Next box was the two calipers, brake pads, lines and bolts. No idea why they sent the lines, most likely a mistake.
The calipers are very light and look gorgeous. I also test fitted the Hel lines into them and they fit! Brake pads are huge, a lot thicker than the EBC Red Stuff pads I have on the factory calipers at the moment.
So there you go :)
Hopefully the other rotor and caliper adaptors arrive soon.
Let me know when you guys get your other parts.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
