Try argue that with WRX scrutineer dickheads. They'll say it's only one "system" so get the extra cable and clip to be sure.
Bit harsh calling the wrx club scrutineers names... but it's true the majority of scrutineers claim that the factory secondary pull latch is part of the same single locking mechanism, hence the requirement for a strap or pins....
  • Replies 146
Posted Images
ok forms are up
http://www.wrx.com.au/motorsport.html
Entries - https://secure1.ilis...tsEntrytemp.php
Supp Regs - https://secure1.ilis...t_Supp_Regs.pdf
Entry List - http://www.wrx.com.a...8fa830675392042
Sponsers TBA
hope to see many of you there
Martin
Hi Martin,
I'm fairly new to the forum and am looking at attending this event. I won't be racing, just a spectator/admirer ;) However a girlfriend of mine is picking up her new 370z this weekend and may like to get into the racing (I doubt it though) - if so, is entry strictly limited to skylines or can other models enter? Thanks.
It is a WRX Club run trackday.
As long as you have a trackday license, fill out the forums and pay your cash, all you need.
There is no car type/model restriction.
You will also need to read the supp regs to ensure you car is upto spec.
fire extinguisher, tow/battery markings, bonnet latch (as its just not worth the hassle on the day), and HELMUT, ankle/wrist clothing/closed shoes etc.
Thanks for the info. See you there ;)
AASA or CAMS is needed, says so in the supp regs :)
There is a section on the online form that you need to enter it into as well.
what he said
from the sup regs
DRIVER ELIGIBILITY
All drivers must hold a current AASA Club Racing Licence or a AASA recognised equivalent standard competition licence or superior and be a financial member of a Car Club.
SO you need to be a member of something Like SAU or equivalent, (that's a paid member not just a forum member).
and have your aasa or CAms.
AASA cheaper at $50 per year.
You should read the full Sup regs as they list what your car needs to past the check in. eg fire extinguisher, your clothing, helmet and such.... if you don't pass them on the day you don't get on the track
M
Supp reg wasn't working on any of my comps at home. So how quick can I become a SAU member and ASaa lisence holder?
SAU membership ask the securatary
http://www.skylinesaustralia.com/forums/topic/288195-become-a-member-of-sau-vic/
All questions on membership can be directed to the Club Secretary at [email protected]
Most clubs let you do AASA on the day check with WRX team at:
[email protected]
I made an early entry for the 2011 "she'll buff right out" award, f@&k!?!!
If i'll be in a car at HH is a long shot, as this chasis is only good for scrap now. i'll be there in anycase.
holy shit!! :O I think you're very lucky to walk away with minor injuries. Looks like you lost the rear but it was too quick to save... what diff to you have? and what tyres and what lap in that session were you on... ?
Far out that must have been the worst feeling heading towards the wall knowing you're about to hit hard.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
