The only explaination is some shit on the track and/or super loss of tallent.
http://www.youtube.com/video/VWhM2bf-LaY
Scary stuff. Glad to hear you are ok.
But FYI I have seen 2 other cars do exactly the same thing in the same spot.
  • Replies 146
Posted Images
Car should be back back on the road and I've not been here before so very tempted.
Question for those that have been before, roughly how many runs can you expect from the day. As of Sunday there were just over 20 entries, as this will head northwards, can't help but wonder how many runs I'd get with only 1 car on at a time.
JP
Just follow the sound of the diesel engine people :digg
Jokes aside, have you got the limiter fitted yet?
You sure do love your diesel Skyline.
