the americans have this, a 16 pin factory connector to the ipod, i noticed my car has the 16 pin connector or somethign similar next to the 3 AUX inputs.
http://www.g35parts.com/Infiniti-G37-Factory-iPod-iPhone-Adapter-Cable-p/284h2-1ba0b-ipod.htm
Will this work with our japanese V36's?
Yes, I believe there is a cable that will make the iPod family work with the car. It is the proprietary cable.
Note - the iPhone only just came out in the US when my car was made (2007), so from what I understand compatibly with the iPhone is questionable. I remember reading on some G35 driver forum that it plays the music but doesn't charge is iPhone 3G because it's missing some chip, or something like that.
Obviously it'll work with the R/W/Y cable, but I'm guessing you won't be able to control the music through the player this way.
I'd love to install a little set top box into the AUX and wire it up to 12V... TV in the car.
i jsut had a look at the stero connector in the car, and nope doesn't seem like it will work. the US cable is 16 pin and the jap one has different shape and the nubmer of pins.
guess we're stuck on the ipod AV cable then, which means no console controlling or integration and changing songs will ahve to be via the ipod only.
Additionally the AV cable doesn't charge an ipod
i'm hesitant to get the AUX (3 input) cable as i heard it doesn't charge the ipod/iphone? correct me if i'm wrong
and the AUX wont play video if the car is in motion.....is that correct?
No it doesnt charge the iphone. I have to unplug the iphone and connect it up with another lead that goes into socket to the left of the aux inputs for charging (its a bit of a pain)
It doesnt play video when in motion, but I know that can be disabled.
Edited by scarf
Hey has anyone actually bought one of these and tried it on a V36 ?????
cheers
cheers
I just use an AV to 3mm plug, it just means you have to select songs manually at the ipod but if your songs are decent you just leave it on shuffle :D
  • 1 year later...
Just wondering...
If you had a Jailbroken iTouch or iPhone with displayout or some other dispay mirror tool installed, could you use these 3 plugs in the arm rest with an apple AV composite output cable, to mirror the apple device on the nav screen using the AV source? If so, then you could get one of the AV cables with the built in USB charger to give a charging solution as well.
Any owners out there find a plug that will charge and play music for an i phone yet?
I seem to cover this topic every week or so on the phone. its not possible to do and control the unit off the radio.
I can sell you a charge lead with audio and video out but thats it.
  • 3 years later...
I'll take one. better yet answer me and I want the whole English conversation
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
