Heya All,
Cheers for all comments - in view of Zanda's comment (below) - i didn't mean to get on here and start questioning ppl - sorry if it turned out that way
I will speak to Bam on sunday and get his story
Thanks again!! And I am SSSOOOOO sick of FWD - i NEED a RWD - turbo import would be sweet :D
Manual
https://www.sau.com.au/forums/topic/35095-checking-out-a-skyline-this-weekend/
As far as I am aware the car has also been in a accident of some sorts recently. I dont know the full details but I would speak to bambam privately about it. Before anyone flames me for it I think its only fair as manual did ask for the history on this vehicle.
manual - I think that you'd best ask bam about it. he's an honest guy.
I dont think that starting a thread on an internet forum about a guy is a particularly good way to buy a car.
After reading this and then re-reading the original post i can see a way to misinterperate what i was trying to achieve - it wasn't my intent
cheers again all - hopefully i can cruise with you lot in a new line REALLY soon!!
Manual
Hey Manual,
You don't happen to drive that Silver Magna with the plates [MANUAL] do you ?
Currently yes - but I am hoping to put those plates onto a Black line in the near future!!
I believe we cruised together at one stage - if you are part of the RICE guys!!
I got into the 14's up the strip in a FWD Family car - but now i want something a lot quicker, RWD, an yeah - a lot more sexy looking :P
Manual
Insurance Broker is the way to go ...... i checked out Just Car n Famous ...... $2.8K i dont think so ..... went thru insurance broker got fully comprehensive for less than what i pay on my parents policy. Funny thing is the insurance company they signed me with CGU i rang them an hour before the Brokers rang them and they said they dont insure imports ...... so going thru a broker definately will open up doors.
Cheers for the heads up on the insurance - already done - got a quote from just cars for $1850 full comp with all mods listed (bit of an excess - but I can cover that if need be)
always helps having a 40% NCB :D
Oh - and i check Bam's car in about and hour!!
Manual
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
