I was quoted from two different places and they are round the same I'd say you'd be looking at around about $40 each machined and extra $40each for slotted or cross-drilled.
Another question and sorry if it's been asked already, I was looking at getting a set of DBA 4000+ rotors for an R33 although I'll be looking at around $900 a set.
Whats the price comparison on a set of R33 GTR (2nd hand) rotors and are they much different from the GTS-T rotors in performance?
I have a set of Bendix Ultimates (pads) going in, should they hold up for track days? or can someone recommend something better for around the same cost?
Cost of Bendix Ultimates - $120 front $109 rear (pair)
I seem to remember some of the guys, at the first Vic club meet, saying good things about the high-end Ferodo's but don't quote me and i don't know what they're worth.
First off do a search, i'm sure its been discussed before, then failing that ask some of the regular track day peoples (you be able to see based on the events forums).
  • 1 month later...
As far as I know, Z32 and R32 calipers/rotors are the same - 280mm rotor
R33 GTS25T brakes are 297mm, so its a decent differance, and worth the extra in my opinion
Depends on what usage your car gets and how fast you want to go
Chris
I have an R32 GTS, which has hopes and dreams of becoming a gtst.. will be doing brakes + suspension + lsd before I do the engine.. so this is getting all the info down before I undertake it.. but i'm guessing a reco'd r32 gtst master cyl wouldnt be hugely expensive
I have done this on my car, unless theres something wrong with your master cyl, dont worry about swapping, i just put the 5 stud hubs on, with R33 GTSt disc and caliper, braided lines and she stops quickly and cleanly everytime
  • 2 months later...
I just got quoted from Race Brakes that the brackets are $500.00 for the pair...
But he wasn't 100% sure.. it said $250.. but it ddn't say if it was for each or not..
Anyone bought these?
Don't worry about it..
Just spoke to Melb Racebrakes... Howard.. he has said not to do this.. he doesn't support it..
So I am following his advise..
Stick with stock setup with slotted DBA, RB74 all round and braided lines..
  • 4 months later...
  • 2 years later...
R32 GTST
Master Cylinder diam (mm) - 25.4
R33 GTST
Master Cylinder diam (mm) - 23.8
R32 GTR (Non V-Spec,)
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9
So i dont see a need to upgrade the master cylinder if you have an R32 GTST and you will be using R33 GTST caliper or R32 GTR caliper.
do you know what R34GTR is? also do you know if this is a straight swap on a R32GTR non-vspec
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
