Hey SAU,
I am having trouble with engine knocking. I have tried a 500ml bottle of Wynns Octane Booster, which claims to stop engine knocking, and there are still knocks. I put the booster in before i filled the car up, drove around slowly for a few mins to help mix it through the tank (like going around roundabouts, swerving side to side down the road *like the racecars do when they warm their tryes*) and still get the knocks.
When i start the engine, there are 1 or 2. whenever i try put my foot down, the number shoots up to about 30-40.
I have to drive 4 hours home tomorrow so i am hoping to get some help by then.
Things worth noting:
I have recently had the battery disconnected, and a larger battery put in.
Before i put the octane booster, after i put the foot down i had 58 knocks. So, the booster helped a little but there are still problems.
I have the following mods- Apexi power fc, apexi boost controller, 3inch turbo back exhaust.
Only run 98 shell V power
The car is on stock boost.
Cheers,
Lachlan
https://www.sau.com.au/forums/topic/351319-engine-knocking/
Go in to settings then inj/ign trim and trim the ignition down 5 degrees until u get a retune.
U will need to do this everytime u start the car as its only temporary.
This should be enough but keep an eye on the knock still
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637042
Speak to whoever tuned your car and get them to have a look at it will probably just need to touch it up abit. If you havent tuned your car and are complaining about knock form just sticking the pre tuned power fc well theres your problem.
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637046
30 is perfectly normal for most tunes and within acceptable range.
The motor will never have zero, in fact you will rarely see the sensor read below 10.
If you are worried about the tune, it's quite simple - Don't drive around on boost.
If you stay off boost, low load/RPM then it should be fine.
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637051
i bought the car tuned, and since the battery came out im guessing it reset itself. Spose i can contact the seller, but regardless i will need a retune it seems.
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637056
The powerfc doesnt reset it self no matter if you disconnect the battery. Either your using different petrol or maybe even the hotter weather conditions have effected it. But yeah Id say best thing would be take it to the tuner and hell quickly chuck it on the dyno and fix it up.
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637064
I just got back from a run, where i set the timing back 5 degrees. It worked, i got a maximum of 9 knocks, with 4 coming from starting the engine (before i could change it). got 5 knocks one way, and then 0 on the return trip.
Is there a way to permanently set it back 5 degrees instead of everytime i start the car? like make it the default setting or something.
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637073
read the PFC FAQ on correcting knocking in my signature
you cant set the temp ign adjust as it clears each time you key off and isn't meant as a permenant fix
ie; you would not want to -5 the whole map, it would suck
you only need -5 deg where its knocking and -2 might even be enough
you need to speak to a tuner and say your car currently knocks as is, but if you -5 deg its fine
and they should adjust the "max load" are on the map and take out some timing
dont let them adjust the "CAS" or back dial it. some lazy tuners do this
dont let them shift the whole map -5 or -2. some lazy tuners do this
you only want the max load area -2 (or whatever the magic number is)
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637140
even 58 isnt all that bad, needs fixing tho. 1 degree from the suspect cell should fix your troubles. as paul said, read his faq, has everything you need to know. could also find someone in your area with datalogit if you dont want to pay for dyno time
btw dont keep using octane booster, once off is ok but it destroys plugs and o2 sensors really fast with continued use
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637148
and it costs you extra money each time and it wont fix the problem, retune the few cells that are knocking and your done
Ok. I read your guide, and i have done for a while now its great :) fixed my airbag light blinking also which was a bonus!
But, while trying to understand the map tracer and changing the ignition timing manually, i have not figured out how to see which cells need to be changed. How can you tell what cell or cells are knocking? and how can you tell what to change them to?
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637226
Bit cheaper then a re-tune but lol?
The map tracer makes it really hard to see where the knock is because it only shows you what cell you are on not what figures you are getting on that cell..... The only way to really do it as far as I know is to find the point where it has a high knock (eg full throttle, 3rd gear, 5000rpm) and then mimic that in map tracer to find the cell where it is getting this bad knock
This is a pain really... Much easier with FC Edit or another program seen as you can log in Map watch what cells are getting which figures.
Im happy to be corrected if wrong but I think eleminating knock on the hand controller is pretty time consuming
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637232
Take it to a tuner and get it tuned.
Just because you have the number 30 there or 50 even, doesn't mean it knocked 50 times. That is a value to tell you the intensity of knock. 50 being higher than 30 for example. 30-40 is acceptable. 50 is getting high. If you take it to someone who knows what they are doing, you may get away with fixing it instead of melting a piston because you changed something you shouldn't
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637245
Exactly. There is no way the PFC was registering "0" knock.
One way up the road, i got up to 9 on the knock meter. then, when i turned around and came back, it didnt change from 9. Thats why i said it had 0 knock.
Before "elite racing" mentioned that the number displayed is actually the level of knock, not the amount of knocks, i never actually knew that. So, its possible that it knocked along the way home and didnt go above 9. I should have switched the motor off after one way, to then see what happened on the way back, but i never knew how the knock counter worked.
I will do more testing tomorrow and see some results, as i will need to refil after the trip home so i will use BP to see if that works to check that possibility. I have booked a tune in for monday afternoon so if it isnt a petrol issue than i will see what the tuner can do.
Thanks guys :)
https://www.sau.com.au/forums/topic/351319-engine-knocking/#findComment-5637302
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
