hai guise, was wondering if there are any home tricks to checking the state of the intake? IE if there are any air leaks?
or do i need to take the car to a shop for them to pressure test it?
cheers
Edited by Clutch
https://www.sau.com.au/forums/topic/351535-intake-leak-test/
I made up a cheap one with some pvc pipe caps and a $20 hand pump. See below photos. I blocked off the pipe going into the throttle body, hooked up the pump to where the pod filter was and pumped away.
The advantage of the hand pump over an air compressor is that because it is quiet it is very easy to hear even the smallest leak.
Do you mean the intake manifold or intake piping? Mine was for the intake piping.
If you get a can of Aerostart or similar and spray it around while the car is idling it should raise the revs if theres a leak as it will suck it in. Perhaps not as good as the method mentioned above but if your looking to do it without spending to much that would be the the way to go
To check for a leak in intercooler, piping or around silicon joins, etc spray with soapy water, preferably while at a high idle (1500-2000rpm is plenty).
If you have a leak it will blow bubbles.
Seems wierd & you may think the water would get sucked in but it works...
Another good one is to remove your pod / airbox so you have access to the afm and while the car is idling cover the afm with your hand so no air can get in.
Then you should be able to hear the hiss of where the air is getting into the intake.
if you have a leak as well, you should blow a small amount of black smoke on boost. some of the air will escape the intake piping, but since it's still being measured by the AFM the correct amount of fuel will be going in as though there wasn't a leak.
Unless you're running a MAP sensor like me. then you're screwed for this idea lol
yes. If the leak is big enough in your case, you'll be sucking in air that hasn't been measures by the AFM while idling or off-boost. This will cause you to run lean, and missfire like a 14yr old boy at a wet T-shirt comp.
Damn you!
I read this thread a couple of hours ago and thought hmmm maybe i'll go look over my intake to see if I have any leaks. Turns out I have a leak coming from under the plenum where the damn gasket has slightly blown out.
God damnit!
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
