To get to this stage took my brother and I in his workshop on a hoist about 2hrs to get the turbo off.
Remove plastic trim around battery and take battery out. Remove engine cover. Undo the main batery cables to engine and pull off the body right back to engine.
Take off the plastic trim under window and you will see a loom. Remove passenger kick panel and unclip the looms that go through the big rubber bung and pull up.
Remove the intake hoses on top of turbo and AFM and air cleaner.
Take off fan and shroud.
Also undo the ABS sensors and unclip to wheel arch.
Remove hoses that are connected from body to engine. And manifold just before the throttle body. Leave the fuel lines. And pull power steering resovior over to side.
Now lift car up. Undo the 4 bolts on tailshaft on back of gearbox. Also disconnect the oil line and bung and cable tie up. Take off the shifter pivot while your there.
Remove lower boost hose to get access to AC
Un bolt AC pump from motor and swing over to where air cleaner was.
Remove exhaust from dump to the muffler.
Undo brake lines at the c clip and stop from dripping.
Now its ready to lower onto stands and take the gearbox crossmember bolts out. Take the strut top nuts off and top ball joint.
Then I think there was 2 or 3 bolts holding the subframe in. Undo them.
One last check to see nothing would get in the way. Raised the car while watching for any jamming and letting the ecu loom go down the back as in the photo.
After the car is raised up from the engine the heat sheild can be removed.
All oil lines and water have to be removed then its just the 4 main bolts on the manifold and off came the turbo.
Photo of the drivers side
Photo of passenger side
Photo of front
Now I thought id look inside turbo I marked the casing and remover the intake housing. It looks like it just touched the surface. The bearings sounds shot its very scratchy. Im thinking its the thrust washer. I cant look at it any further today as i need more tools. Im hoping I can get a garrett kit and do it myself. I have before done a kit on a turbo on my last 33. But I would hate to have the turbo out again.
What do people reckon would this be an easy fix for a handy man that just passed all of the above and try and fix it myself or get it rebuilt.
From the pictures in the photo off the fins do people think i will get away with them.
How do you tell if the exhaust wheel is steel or ceramic it has a metal sound to it when you lightly tap it.
It was going to be 42deg today in SA so it was get it done quick.
  • Like 1
https://www.sau.com.au/forums/topic/352166-m35-engine-and-turbo-out/
You could get a garrett 3071 core and machine the housings or just go bushed core like most of us have. Our core is not rebuild-able and is ceramic rear wheel.
Nice job getting the engine down, I do all my work on the ground, just lowering the gearbox a bit. Theres room to remove it but I have made a few special tools to help.
If you need some numbers to ring for turbo rebuilds, just ask. :thumbsup:
Garret GT3071 cores come with wheels and are balance from garret, you only need to machine the housing.
perhaps you could buy the core, take it to a turbo shop with you stock turbo and say make this work lol
just a head's up with the 30/71 core......it's takes a lot to get it going properly.....it's very laggy until everything is done.
Well done getting the motor out in that time Brad.....it's a lot easy now to do everything that needs to get done!
a magnet will tell you what the exhaust wheel is made of .
yeah get it highflowd.
also interested in the kit from garret you built your 33 turbo with ????
I just rang MTQ and told them I had a Garrett TB3401. They gave me a kit with bush bearings, piston seals, gaskets and o rings. Everything basically except the turbines. As long as you dont have a nut with grinds on it on intake turbine because its balanced with the turbune and shaft. You can reasemmble them if they have a standard nut because everything is balanced seperately. Followed some instructions and it never had a problem again.
so was that the standard turbo ? or an aftermarket one? or you converted the standard ball bearing one to bush bearing ?
It was aftermarket. It only just fitted in the low mount position. And was allready bush bearing.
I had to put the car back down on the engine and gearbox today and take off hoist. My brother needs his hoist back. Then I get to do it all again next week.
Ive finally getting mt turbo fixed. Bill at ATS in Adelaide is getting me a GCG changeover like [[danny]] has on his M35. Bill also did danwatts turbo which needed a few mods to fit. My changeover is direct bolton.
Also got Scotty making me a dump while im at it Thanks.
Make sure you open up the banjo on the front of the motor for oil feed for the GCG or Garret BB set's!
Danwatt's turbo was a Garret BB set with a GT30/71 core wasn't it?...same as mine!....the Garrett BB set is 20mm shorter than the GCG BB set / standard turbo!.
If you have gone with the Garret BB set the below pic will be some help.....these are the parts you will need to make up!
Edited by Jetwreck
I guess you mean the small hole in the side of the banjo bolt to open up. Would you have a size to open it upto. I would think going to big would cause to much oil. Does that mean also that the banjo bolt on the turbo needs to be opened? And yes its going to be GCG BB
Danwatt did a flow test on it ......you need to open it up fully as per the end of the banjo...not as the inner of it!...if that makes sense!..maybe it will when you get the bolt out!
.....I didn't have to open up the banjo on the turbo as it was already the correct to the line size.....my turbo builder has informed me that that is what I needed to do to get flow up to the Garret BB set.
I am worried you may be supplying the wrong information here buddy, my turbo has bush internals, usually requiring more oil flow than bearing jobs, I have had no issue with mine for over a year at 20psi, added to the fact your Garrett core has a secondary restrictor built into the oil supply fitting on top of the turbo.
I found this today, how big is 30 thou?
http://cgi.ebay.com.au/TIAL-OIL-SUPPLY-FEED-RESTRICTOR-FITTING-GT-TURBO-0-030-/160507751949?pt=AU_Car_Parts_Accessories&hash=item255f01ee0d#ht_1118wt_905
That said, I was advised by ATP today that I should be opening the restrictor up to 1/8th or 3mm only as that is what the skylines run. Im not sure what to do now, perhaps just leave it?
http://cgi.ebay.com....d#ht_1118wt_905
You're right Scotty, Bush bearing turbos definitely require more oil flow than Ball Bearing turbos. While this is Garrett's own info, it still applies;
http://www.turbobyga...enter/faqs.html
Does my turbo require an oil restrictor?
Oil requirements depend on the turbo's bearing system type. Garrett has two types of bearing systems; traditional journal bearing; and ball bearing.
The journal bearing system in a turbo functions very similarly to the rod or crank bearings in an engine. These bearings require enough oil pressure to keep the components separated by a hydrodynamic film. If the oil pressure is too low, the metal components will come in contact causing premature wear and ultimately failure. If the oil pressure is too high, leakage may occur from the turbocharger seals. With that as background, an oil restrictor is generally not needed for a journal-bearing turbocharger except for those applications with oil-pressure-induced seal leakage. Remember to address all other potential causes of leakage first (e.g., inadequate/improper oil drain out of the turbocharger, excessive crankcase pressure, turbocharger past its useful service life, etc.) and use a restrictor as a last resort. Garrett distributors can tell you the recommended range of acceptable oil pressures for your particular turbo. Restrictor size will always depend on how much oil pressure your engine is generating-there is no single restrictor size suited for all engines.
Ball-bearing turbochargers can benefit from the addition of an oil restrictor, as most engines deliver more pressure than a ball bearing turbo requires. The benefit is seen in improved boost response due to less windage of oil in the bearing. In addition, lower oil flow further reduces the risk of oil leakage compared to journal-bearing turbochargers. Oil pressure entering a ball-bearing turbocharger needs to be between 40 psi and 45 psi at the maximum engine operating speed. For many common passenger vehicle engines, this generally translates into a restrictor with a minimum of 0.040" diameter orifice upstream of the oil inlet on the turbocharger center section. Again, it is imperative that the restrictor be sized according to the oil pressure characteristics of the engine to which the turbo is attached. Always verify that the appropriate oil pressure is reaching the turbo.
The use of an oil restrictor can (but not always) help ensure that you have the proper oil flow/pressure entering the turbocharger, as well as extract the maximum performance.
1 thou = 0.0254mm
30 thou= 0.762mm.
Edited by Daleo
1 thou = 0.0254mm
30 thou= 0.762mm.
exactly as I thought. now based on our banjo plug hole being 1mm, is that adequate enough for the amount of oil Pressure we have in the VQ Motor. IIRC, the VQ has almost twice as much oil pressure as an RB.
But Scotts Turbo is going strong at 20psi for a year, and andy65b has his banjo opened up and says no worries.
does our core have another restrictor in it??
That I may be!....but what killed Aaron's? .......... every time I hear the GCG BB set(or similar) I get a cold shiver when the motor is turned off or reving....I have heard supercharge's quieter....bb's are not supposed to make that sound!
In saying that does the GCG have a secondary restrictor?
You know I have opened up my Banjo and have never had a hassle with too much oil going through the system.....and that's 2 years at 18 -19PSI!...plus about 4 days at past 20PSI!
From memory the problem is at idle our car produces about .9Lpm with the 3.5mm banjo on the turbo.....I needed to get it up to about min of 1.6Lpm to a max of 1.8Lpm on idle for the Garrett BB set(and may I add I also think the GCG needs the same luv'n).
P.S. Good read above Dale!
Edited by Jetwreck
That I may be!....but what killed Aaron's? .......... every time I hear the GCG BB set(or similar) I get a cold shiver when the motor is turned off....bb's are not supposed to make that sound!
I remember you saying the same thing about Danny's GCG BB, that was LOUD!
Might be doing a turbo on mine soon too...:whistling:
I think it was a shit bearing set up. to tight? incorrectly inserted? im not sure, never saw it opened.
Turbo guy says, its a snapped blade on the fan, and due to this its unbalanced itself, and was rubbing and making that sound.
but neither of the above explains why it went aay on boost. Maybe car is to loud to notice, and I personally wasnt expecting to listen for anything.
So you have a 3.5mm banjo on the GCG? at the oil pressure your running now shouldnt that be too much for the turbo?
I'm also being told that I shouldnt be opening the banjo any more than 3mm or 1/8th for journal bearing. which means that 3.5 *must* be too much for the gcg BB core.
whats the size of Bnjo on the GCG Craig?
How do you snap a blade on the steel fan? low oil feed at idle explains it to me better than a freak blade breakage!
I don't know what GCG have as a restrictor.....I lost interest with GCG after they said there baring set for our turbo was only good to about 450HP....GCG say you don't have to do anything to our car....just bolt it up.....IMO that's wrong!....I have heard GCG unit's on other cars and they sound nothing like ours!....which leads me to the assumption that while I am sure GCG can build a very good turbo there thinking is typical of the rest of the numpty suppliers out there that have no idea about the VQ25DET motor!
Without doing an flow test with different restrictors who would know on our car what is the correct restrictor is to go with what combination! I'm just going off the info my turbo guy gave me when he handed me back the new unit!...and the previous result's found from someone else that did a flow test and had the same turbo as me!
Edited by Jetwreck
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
