shit i love this car
any updates on this ??
Yep, plugging away at it in my spare time!
After a bit of back and forth with PWR and lots of measuring a radiator arrived. Looks pretty good and fits well.
F20A5F09-7CA5-46BA-932D-495F913923FB_zps
I've also collected most of the materials for the header tank and swirl pot, so a few trips to the fabricator and it should be going again. Hoping to give it a shake down in the next couple of weeks.
  • 3 months later...
Well it's been another painful few months. Got the radiator and new swirl pot + header tank combo in, fired the car up and it promptly dropped two cylinders. Turns out the cdi had dropped a capacitor so it was sent back to Autronic for repairs. Autronic strongly recommended upgrading the chip in the ECU since I'm about 5 versions out of date so I elected to do that at the same time. What a massive mistake that turned out to be!! Two additional trips back to Autronic in Vic, three SM4 chip versions and three or four months later and it's finally running again.
I got it down to MC Motorsport on Friday for a test & tune session. Running only 1bar and revving to 6k it still went pretty well. Having a bit of a problem with oil surge under acceleration which is odd considering it's fine on the street - I'm hoping it's the sump running a bit low with sustained high'ish rpm resulting in surge since it's an easier fix than pulling the sump off.... The accusump looked after things but nevertheless I need to get to the bottom of that one before I have another crack.
AC3D6E40-633C-4090-8EB1-9B1D353E0F75_zps
F4001F4C-7BBE-4B5F-AC2A-B8B0EEA862FE_zps
Some in car video from the shakedown, taking it pretty easy on account of the oil pressure.
That's awesome :) Must be a delight to drive!
Who ended up building the bottom end?
It's heaps of fun and should be even better once the cam timing has been sorted out with a bit more boost! Peter Gray built the engine.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
