I always shoot in full manual
First time shooting at night with my prime lense. Had some issues with focus but these two seemed ok. Might be how they are resized like you said. The lense is pretty sensitive to what is in and out of focus but so I may have been just a bit off
the second one is in focus, the focus point is the rear windscreen tho.
with the first one turn the car wheels so the face of the rim is facing the camera instead of the tyre ;)
its not as in focus either. maybe try stopping the lens down a bit more too as 1.8 open wide isnt always that great for car shots as the DOF is a bit too small except for detail shots.
still pretty cool though, wish i wasnt so lazy keen as to do night photos but never have the motivation to get out there and do it, lol.
Edited by Jay019
Ah ok, Maybe thats my problem
Last time I took car shots at night they had alot of noise and I realised afterwards I had my ISO right up (whoops). So the photos looked alright on the little camera screen but as soon as they went on a laptop there was far to much noise in them. Beginner mistake, something I should have relised but oh well...
I Think thats why I was overcompansating with the lowest ISO I could use and adjusting the apature right down So I wouldnt have to drop the shutter speed (If I'm further off doing the right thing then I relise here I'm happy to take some constructive critisism, ISO was at about 400, Apature at 1.8 and shutter speed was between 1/20 and 1/40 or around abouts. Like I said but I overcompansated with the ISO cause of last time)
Ill put another 2 photos from the night up. The Lighting in the Skyline one isnt right, but Its a bit better focused. The one of the monaro I think suffers from the same issues as the above photos but not as bad (now that you guys bought it to my attention lol...)
Like I said I'm open to critisism, I dont mind these photos but I know there a long long way from alot of you guys in here. But I'm willing to learn and try out different shooting methods. I like to think I'm slowly improving lol
Thanks
P.S. That first photo of my car where you said the wheels are facing the wrong way..... I was parked Illegally in the middle of a road so just ran out to grab a photo before anyone came haha. Should have thought about the angle of the wheels in alot of these photos but I was being pretty lazy on the night
Edited by 89CAL
Here's some I took at Circuit Club's Twilight event last Thursday night.
Here's Matt:
Some random S2k in the next garage:
A really nice Evo also sharing the next garage (and "Aggroman" Dave in his R34):
"Pezhead" Eric's engine:
And Dave's R34 again:
along with the man himself (kinda :P ) as well as Eric giving Dave some pro tips:
Sorry about your loss mate.
We've had her about 7 years and she was living in a friends front yard, so she doesn't lay too often these days. Still get a few, if we can find them :P The dog usually follows her around, they're good friends! Lol
Damn I'm hot in a helmet. When you can't see my face i reckon i have a pretty good to average looking face ;)
Hahaha - for a second there I thought you had some crazy weird fluffy animal hanging from the front mirror :P
Ps two taken during our Simpson Desert trip last year:
Dingo Tracks by ZENN0N, on Flickr
Staring into the desert by ZENN0N, on Flickr
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
