hey all im currently building an rb26/30 for my 32gtr just wondering was sort of gains i should expect ie power gains / response and if there is anything more i should do before assembling
it was making 300rwkw before on 15psi of boost with the following mods and standard rb26
T04r top mount turbo
blitz 660cc injectors
straight throught 3" exhaust
apexi afc neo piggy back ecu
bosch 040
malpassi fuel pressure reg
piping kit
everything else pretty much stan dard
Mods i am in the process of doing/building
upgrading to bosch 044 with surge tank
mahle pistons and rings
forged h beam conrods
ported head
sump adaptor
rb30 bottomend bored .040 acid didpped and all that
ross harmonic balancer
apexi power fc djetro
crank balanced and all that
race bearings
i think thats about it might be a few things i left out but yea just intereston what people think and what sort of gain i should expect when its complete?
cheers
https://www.sau.com.au/forums/topic/352571-r32-gtr-2630/
  • Replies 43
Posted Images
The best gain IMO - swapping to a better turbo. Its without a doubt the sore point of your setup.
You can increase displacement and all the rest, but the best gains are simply in one single item.
A GT35 will be more responsive and make more power than what you have on there now IMO.
https://www.sau.com.au/forums/topic/352571-r32-gtr-2630/#findComment-5652479
yea i was thinking that or getting one of those kits that put t04z internals into my turbo but that will be later on i reckon
i also forgot to mention atm it hit full boost about 5k rpm so hoping that will improve a bit
and im running oil drain from the back of the head to the sump as well as oil ristrictors
https://www.sau.com.au/forums/topic/352571-r32-gtr-2630/#findComment-5652500
See a GT35 on your current motor would drop a good 500rpm just from the turbo
Add in a 3ltr and you'll be looking at 1000rpm perhaps more.
IMO it's the best turbo choice for your setup as you are limited by other parts like injectors, ECU etc.
And really - you need a proper ECU to control your setup.
https://www.sau.com.au/forums/topic/352571-r32-gtr-2630/#findComment-5652508
yea i was planning on getting an apexi power fc djetro will this be good enough or should i look into getting a haltech or something more like that?
https://www.sau.com.au/forums/topic/352571-r32-gtr-2630/#findComment-5652528
T04Z is too big for your current part list, a GT35 is only JUST going to squeeze in.
If you want 400-440rwkw+ (T04Z), then you need bigger injectors, 4" exhaust etc. Basically another 3-4k is required.
And then budget for a gearbox with that kinda power, as realistically they don't hold that power forever - so 5-7k.
I still think the GT35 is the best choice mate, and it's more-so affordable in terms of not stressing "too" much more than needs to be. 360-380rwkw through a stock box should be OK. But going much more and you really are starting to strech the relationship a bit.
https://www.sau.com.au/forums/topic/352571-r32-gtr-2630/#findComment-5656946
yea i will just wait and see how this turbo i have atm goes with the setup i was only going to go a t04z because u can get those CHIRA things for $1000 and they fit into the to4r housing
what are 660cc injectors good for does anyone know?
yea im buying a new exhaust atm gonna get a 3.5" i reckon
and yea my gearbox is already in need of a rebuild whines its head off and grindes from 3-4 at high rpm
https://www.sau.com.au/forums/topic/352571-r32-gtr-2630/#findComment-5657121
3.5 isn't enough for a 04x, needs 4' due to 400rwkw+
a core is cheap, but you could sell the 04r, and it'll workout the same ;)
i may aswell look into 4" then haha where the best place to buy them from dont see 4" very often
yea i guess so ill sort that all out after i finish the build and have saved some more money :)
https://www.sau.com.au/forums/topic/352571-r32-gtr-2630/#findComment-5657805
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
