+12 offset should look pretty mad.
Getting them off Boost Automotive, Brad's got the best price I found. I'm also getting some tyres off him, amazing price also.
Edited by zoidbergmerc
18x9.5 +12
I haven't bought them yet, just a test fit today.
Rears are nice a hella flush, heaps of room for everything. Front are a bit of a troll though. I'm going to measure the shit out of everything tomorrow and see what needs to change. to make it work.
Bolt on what? I don't know what you're asking!
I forgot GTR Guards were an option... Does anyone have any? do they bolt straight onto a GTS? Can I keep my blue NA GT badges? pirate.gif
What's the difference between the GTR and GTS guard? are they actually bigger? it's hard to tell in the pics :/ I see the indicator is smaller and there are some extra holes for more trim but that's it?
GTS Guards are so cheap I might as well just get a pipe onto my stock ones yes?
Edit: seems you need the guards, raisers, GTR hinges, bonnet and latch. to have GTR guards... hmm.
Going to get my pole on then. Fitment on these wheels just look too boss to not have.
Still going to paint the rim blue though. Do you think it'll be easier just to brush it on with some awesome modeling paint or something? because masking a perfect circle sounds like it'd be hard to do :/
why not just get a less aggressive offset on the front. its not a gtr so you dont need "gtr" sized wheels. plus wider track in the back will improve stability.
just an idea.
or more camber if you have upper arms?
or put r32 lower control arms in as they are shorter then shorten up the tops.
or dont do the last one.
just an idea.
You're starting to sound like a woman. "less aggressive", "shorter", "don't", Cmon man!
I've already got -4 degrees neg on the front, maybe should wind some more neg on, but I know the dude at beauepairs will have a teary about it then start comparing his KE70 to my car.
yea that may be right. some people say i have a massive V, but it also comes from experience with wheels and fitment or not, just trying to save you the stress and hassle of modifying guards at the track. i can guarantee when you spin off and hit a ripple strip with the wheels hanging out there wont be enough travel to save the guard. getting the correct size now will save in the long run.
Yeah, I'm just yanking your chain, I appreciate your advice and know you've got a wealth of experience :)
The plan is to raise the front about 5mm (it's too low atm anyway) and get my pole on and roll those guards up, wish me luck :D
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
