+12 offset should look pretty mad.
Getting them off Boost Automotive, Brad's got the best price I found. I'm also getting some tyres off him, amazing price also.
Edited by zoidbergmerc
18x9.5 +12
I haven't bought them yet, just a test fit today.
Rears are nice a hella flush, heaps of room for everything. Front are a bit of a troll though. I'm going to measure the shit out of everything tomorrow and see what needs to change. to make it work.
Bolt on what? I don't know what you're asking!
I forgot GTR Guards were an option... Does anyone have any? do they bolt straight onto a GTS? Can I keep my blue NA GT badges? pirate.gif
What's the difference between the GTR and GTS guard? are they actually bigger? it's hard to tell in the pics :/ I see the indicator is smaller and there are some extra holes for more trim but that's it?
GTS Guards are so cheap I might as well just get a pipe onto my stock ones yes?
Edit: seems you need the guards, raisers, GTR hinges, bonnet and latch. to have GTR guards... hmm.
Going to get my pole on then. Fitment on these wheels just look too boss to not have.
Still going to paint the rim blue though. Do you think it'll be easier just to brush it on with some awesome modeling paint or something? because masking a perfect circle sounds like it'd be hard to do :/
why not just get a less aggressive offset on the front. its not a gtr so you dont need "gtr" sized wheels. plus wider track in the back will improve stability.
just an idea.
or more camber if you have upper arms?
or put r32 lower control arms in as they are shorter then shorten up the tops.
or dont do the last one.
just an idea.
You're starting to sound like a woman. "less aggressive", "shorter", "don't", Cmon man!
I've already got -4 degrees neg on the front, maybe should wind some more neg on, but I know the dude at beauepairs will have a teary about it then start comparing his KE70 to my car.
yea that may be right. some people say i have a massive V, but it also comes from experience with wheels and fitment or not, just trying to save you the stress and hassle of modifying guards at the track. i can guarantee when you spin off and hit a ripple strip with the wheels hanging out there wont be enough travel to save the guard. getting the correct size now will save in the long run.
Yeah, I'm just yanking your chain, I appreciate your advice and know you've got a wealth of experience :)
The plan is to raise the front about 5mm (it's too low atm anyway) and get my pole on and roll those guards up, wish me luck :D
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
