hi i was on way to adelaide from lismore nsw and just out of broken hill i noticed no boost so i stopped and let turbo timer do its job then when turned off heard a whirling loud sound coming out of back turbo
car 32 gtr with 2860 's on it what should i do i have to have it on train in adelaide on sun arv to be sent over to perth where i am moving too.
whay would be best thing for me to do ??/
0411373366
dan
it's hard to say.
if you have just lost the rear wheel (0 boost) but the turbo core is OK, keep driving. Any damage is already done and it won't get worse.
but if the core is damaged - whirring/whisting noise, you can end up with shit in the oil from the turbo bearings which would damage/kill the motor if you keep driving.
If you aren't sure....you need to get it on a truck. rebuild is $5k+ so that is what you are risking
yeah they are steel wheeled garret 2860s -5 ball bearing
i dont understand how this happened its makes a whirling sound the (rear one) i need to get it on train on sun arv so should i not drive it till then ??
im so dissapointed
a question how much boost can these turbos run ? i was running 20 ....
intercooler pipes are not the issue its making a noise the rear turbo .
