  • Replies 163
Posted Images
I have to say a MASSIVE thanks to Justin (the supplier of these injectors) for the massive help he's given me with a few problems I've had that were out of his control. His service was second to none and I rate his professionalism and helpfulness as some of the best out there. Don't even hesitate to think about buying from him; just do it!
In other news, I've got the car running as can be seen in the video posted above, I just need to get it in for a tune now and all will be sweet
no group buy ends 04/03/11 and refer to quote
All prices above are for a group buy only. This assumes 1 order, 1 payment, 1 delivery address. Payment via bank deposit only. Paypal payment will incur 2.4% surcharge. Please allow up to 2 weeks after payment for order to be dispatched.
how ever it is possible for you to pay full price from the supplier and get your own shipped to you
yep, thanks its just standard
i need to contact the supplier to find out about something otherwise you will need
80lb Siemens $345,
wiring harness $42,
Blue fuel rail $225
shipping $25 Total $637
More information taken straight of his ebay page
Available in:
Red and blue for RB30. Chrome can be optioned for $20 extra.
Red, blue and gold for RB26. Please note RB26 rail kit can run both 11mm and 14mm Oring injectors. Chrome can be optioned for $20 extra. Gold currently out of stock.
Blue only for RB25 (suitable for R33 RB25 only)
Please specify which of the above you require when ordering.
Rail kits do not come with injectors. Aftermarket fuel regulator will need to be used.
I was after a pic of the id2000 rail
Cheers
he said the fuel rail suits the injectors which suit your car picture's are very similar
also
just got off the phone to the supplier and he can supply 10.5mm hats for the 3/4 length injectors
they will be more expensive than the 11mm hat that is supplied for aftermarket rails that take 11mm
when ordering please do as much asking of your tuner what sort of options you have available, i would hate for people to order the wrong parts
for the r32's do the injectors have to be Hi-Impedance?
ive got 700cc siemens low-impedance in my 32 atm . . .
Edited by I8EE
does your 32 run the same low impedance thing that GTR's run?
On Edge - any type of aftermarket FPR will work im getting prices on some Tomei ones
also
Good news on the RB26 height adapters for use with the EV14 Bosch injectors. I can do the 10.5mm adapter for $8ea extra on top of the original price. I will need approx 2 weeks lead time though once we have numbers.
Good news for the 80lb boys, please put me down steve for 80lb injectors to suit r33 rb25, also fuel rail an adaptors if neccesary.
Maybe a z32 aswell mine maybe stuffed ill let you know on that one so don't put me down as yet.
1000cc are 3/4 length and need the height adapters
you can get the 80lb/h close the 1000cc (95lb/h) with more fuel pressure your tuner can advise on this though
**note**
price change applied to those wanting the 80lb/h injectors
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
